'87 efi 22re 4x4 idles fine in 4wd, but sputters/dies in 2wd at low/mid rpms
Old Jun 9, 2015 | 07:43 PM
nbondi's Avatar
I've searched a bit and haven't found any threads that address this.
Truck starts fine. It idles fine in 4wd, but in 2wd, sputters and dies at low rpm, AND when I give it some gas. At higher rpms, it eventually evens out. Problem is less bad when engine is cold.
Shop says there aren't any vacuum leaks. Replacing harmonic balancer helped, but still pretty bad.
Any help with where I should start hunting....either on the truck or in threads here?
Truck has plenty of other problems that could be contributing, but I don't know enough to know which ones matter.
Old Jun 10, 2015 | 12:28 AM
wyoming9's Avatar
Red face
I am willing to bet you have a automatic Transmission Correct??
I don`t really see how a manual could cause this problem
Now if it was a newer vehicle with ADD I could see a vacuum leak when the shift lever was in 2wd.
which could be missed quite easy.
This is off the top of my head without checking .
Old Jun 10, 2015 | 08:06 AM
nbondi's Avatar
Yep. It's an automatic.
Yont283
Sep 23, 2022 08:06 PM
zd92655
Mar 6, 2022 12:58 PM
Team420
Jan 12, 2021 04:57 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Fred Anarat
12
Aug 27, 2002 04:50 PM
