'87/'88 (lower intake?) coolant hose availability
Hi,
I recently pulled off the cylinder head on my '87 4runner, and there are 3 coolant hoses located around the front of the lower intake manifold. There are 2 located under the manifold, and 1 located on top near the water neck. These are smaller diameter hoses. The 2 lowers look to be 1/4" and 1/2" diameter, and the upper is 1/4". If there is anyone who knows what I am referring to, I am looking for somewhere that supplies these hoses new. I should mention that there is a chance this motor is from an '88 4runner, but I can't be sure.
Thanks very much,
Tim
Thanks very much,
Tim
I was able to get the coolant hoses through the local dealership. I had to bring in the cylinder head/lower intake assembly to show them what I needed. Took a bit of searching, but they found all four hoses. In case anyone is interested, here are the part #'s:
16261-35030
16281-35010
16264-35012
16267-35030
The receipt labels them all as test hoses. This looks like it is an '88 setup. All the part #'s come up as working on an '87 or '88, except for 16267-35030. That number is only listed as '88 and later.
So, if you are looking to replace those smaller coolant lines close to the #1 cylinder, these should do it. Hopefully, this will help someone in the future. I'll try to post pictures in the next few days for reference.
-Tim
16261-35030
16281-35010
16264-35012
16267-35030
-Tim
the1998sr5
15
Jul 14, 2020 08:35 PM
94 Newbie
Aug 6, 2015 10:33 AM
Poncho0206
Jul 10, 2015 06:21 PM
