'87/'88 (lower intake?) coolant hose availability
Old Jul 26, 2011 | 08:21 AM
Timo's Avatar
Hi,
I recently pulled off the cylinder head on my '87 4runner, and there are 3 coolant hoses located around the front of the lower intake manifold. There are 2 located under the manifold, and 1 located on top near the water neck. These are smaller diameter hoses. The 2 lowers look to be 1/4" and 1/2" diameter, and the upper is 1/4". If there is anyone who knows what I am referring to, I am looking for somewhere that supplies these hoses new. I should mention that there is a chance this motor is from an '88 4runner, but I can't be sure.
Thanks very much,
Tim
Old Jul 26, 2011 | 01:38 PM
wyoming9's Avatar
Smile
Make friends with your Local Toyota dealer Parts people
If you can sill get them or make your own making them long enough not to kink.
Old Jul 26, 2011 | 05:26 PM
Timo's Avatar
I was able to get the coolant hoses through the local dealership. I had to bring in the cylinder head/lower intake assembly to show them what I needed. Took a bit of searching, but they found all four hoses. In case anyone is interested, here are the part #'s:
16261-35030
16281-35010
16264-35012
16267-35030
The receipt labels them all as test hoses. This looks like it is an '88 setup. All the part #'s come up as working on an '87 or '88, except for 16267-35030. That number is only listed as '88 and later.
So, if you are looking to replace those smaller coolant lines close to the #1 cylinder, these should do it. Hopefully, this will help someone in the future. I'll try to post pictures in the next few days for reference.
-Tim
the1998sr5
15
Jul 14, 2020 08:35 PM
94 Newbie
Aug 6, 2015 10:33 AM
Logz808
Jul 26, 2015 07:09 AM
jjrbus
Jul 23, 2015 05:05 PM
Poncho0206
Jul 10, 2015 06:21 PM
