87 4x4 truck 22r Water pump pulley
I put a new water pump on my 22r and the pulley seems to hit the bolts on the water pump, as far as i can tell the pulley is not bent, could i have the wrong bolts in the wrong locations? or is there supposed to be a spacer of some type between the water pump snout and the pulley?
check the plate that the pulley goes over, the one with the studs ,to see if it is on straight. i had a water pump on a chevy that the plate was pressed on at an angle. the pulley would hit the housing of the pump on one side when it rotated.
nothing on backwards, the plate with the studs was pressed too far on to the pump it was nearly touching the pump housing. of course the second time i put the pump on i sheered a bolt so now i get to have that fun
voiddweller
19
May 2, 2016 09:10 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
