87 4runner Problems
Old Jun 24, 2011 | 02:10 PM
dparker's Avatar
I agree but I am not getting injector pulse at all so weather im pumping gas water or rust I stile should get injector pulse
Old Jun 24, 2011 | 02:17 PM
1styota4X4's Avatar
and the cold start was working good? did you clean it? The pulse is from the coil/ignitor to fire the injectors. are you getting good spark?
Old Jun 24, 2011 | 03:57 PM
dparker's Avatar
Yea getting hot spark
Old Jun 24, 2011 | 09:20 PM
weaselman's Avatar
gas goes bad after 30 days. it varnishes and turns to a honey like substance
i would go through the whole fuel system. specially if it ran great for 5 min...means it was getting fuel, then it stopped. so its partially clogged.
and if the injector is clogged it wont pulse.
Old Jun 24, 2011 | 09:56 PM
  #25
dparker's Avatar
I agree but I'm testing injector signal from ECM injector harness unplugged using noid light no signal , I've already checked injector screens an filter, I'm having a no signal from ECM, checked wires 10 an 20 from ECM there good replaced ECM with known good ECM no diff , so I guess it's rime to trace the igf wire to ignitor an the swap ingnitors , any other ideas???? Anybody need to buy a 4runner on 32's lol
Old Jun 24, 2011 | 11:42 PM
  #26
Bassmastry101's Avatar
How about the ground that goes to the intake? Took me a while to figure that one out. So if your getting a reading at the ecm side, but not at the injector side of the harness, could there be a broken/pinched wire somewhere?
Old Jun 25, 2011 | 05:55 AM
  #27
dparker's Avatar
I am not getting a signal at the ECM so I'm defiantly not going to get on at injectors, if there's a ground on intake off I haven't found it
Old Jun 29, 2011 | 05:22 PM
  #28
dparker's Avatar
No ground problem even added more there is no ECM pulse at or around the ecm
Old Jul 2, 2011 | 12:08 PM
  #29
dparker's Avatar
I found I found it!!!!!! Dint no what the crap it's called but sum kind of sensor connect to coolant an two big vacuum lines pretty much under num 1 injector two wire plug in the two wires were touching killing power to computer some how . Need a new connector what is that sensor called?
Old Jul 2, 2011 | 12:17 PM
  #30
eric924run's Avatar
Chck your ground wires for your ecm. also check ground wire from body to battery and engine. make sure all have good clean and tight connections.
Old Jul 2, 2011 | 12:21 PM
  #31
dparker's Avatar
I said I found it just would like to no what that part is called
Old Jul 2, 2011 | 12:31 PM
  #32
93toyrunner2's Avatar
Pics Help
Can we get a picture of it??
Old Jul 2, 2011 | 12:46 PM
  #33
dparker's Avatar
Yip but b a bit can't upload from my iPhone
Old Jul 2, 2011 | 12:59 PM
  #34
skypilot's Avatar
Mine sat for longer. The gas was varnish. You have to pull the tank out and flush. Also your pump may have siezed from varnish forming ( mine did). The fuel filter maybe plugged with varnish too.
You may have hurt your cause with bad gas and trash that is now up in the injectors and fuel rails.
The injectors work by switching grounds in the ECU. Make sure everything is grounded properly including the intake manifold. Check the ground under the ignitor to the fender well too. must be zero ohms. Also the ECU case must be grounded too!
Old Jul 2, 2011 | 01:08 PM
  #35
dparker's Avatar
Again I found the problem with this two wires touching killing the computer it starts an runs fine but need to get a new connector for whatever the he'll that sensor is big vacuum line that goes to idle screw an coolant lines it's rite below number one injector
Old Jul 2, 2011 | 02:14 PM
  #36
gorillaman2012's Avatar
ya picture would help..sounds like a pressure regulating valve. the screw is meant to be adjustible
Old Jul 2, 2011 | 06:04 PM
  #37
toyotacharles's Avatar
sounds like cold start injector time switch or ect for ecu, those are ther two sensors just below the tstat near #1 cylinder,
  #38
DirtyOregonKid's Avatar
where are you? perhaps a local user can ID the part for you..
Old Jul 2, 2011 | 08:40 PM
  #39
paintthetown's Avatar
Diagram: (8408-8808)22REC,22RTEC diagram in a new window
Numbers on the diagram are Toyota PNC. Numbers with "Refer to Fig" in the front are No. for other vehicle categories.
Is this it?
Old Jul 8, 2011 | 10:44 PM
  #40
weaselman's Avatar
its probably the theromstatic switch for the computer..
is it the green or yellow one. is it the right or left?
if its the sensor im thinking of, there are two of them next to each other...
but again, a pic would help...hahah.
Yota.Jay
Jul 23, 2015 08:08 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
