87 22re wont rev over 2200rpm????
Old Oct 9, 2010 | 07:48 PM
mxracer186's Avatar
Thumbs down 87 22re wont rev over 2200rpm????
what a headache, i have a 85 extracab 4x4 that had an automatic trany and a 22re with a bad crank. I installed a 5spd trany and had 22re out of an 87 pickup completly rebuilt. After all the work i drove the truck daily for about a month with no problems. Now it will not rev over 2200rpms, i have replaced the tps and am some what sure it is not the problem, also tried a diffrent air flow sensor, and installed a new fuel pump and filter. hopefully some has a better ideal than me
Old Oct 9, 2010 | 08:31 PM
mightymouse's Avatar
what do the plugs look like?
Old Oct 10, 2010 | 11:12 AM
mxracer186's Avatar
the plugs are dry but do have a dark soot on them, also not to sound dumb but not sure where to ckeck for a blocked converter.
Old Oct 10, 2010 | 11:34 AM
mxracer186's Avatar
pretty dumb, u meant a blocked cat converter. there is not a cat converter on the truck
Old Oct 10, 2010 | 12:52 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I see you've replaced your TPS, just curious, you adjusted it, right?
It's my understanding they can't be put in. They must be adjusted in.
Does it cut-out (like a rev box) at 2,200 like it's an electrical issue? Or is it smooth like a air, fuel or clog issue?
Old Oct 10, 2010 | 03:44 PM
mxracer186's Avatar
I did adjust the new tps per specs on 4crawler. I believe it to be electrical,it runs very smooth at idle and anywhere else below 2200rpms. I also checked the timing.
Old Oct 10, 2010 | 03:53 PM
raydouble's Avatar
Does it pop and spit under load or do RPM's climb nicely, just stop at 2200.....
Starts spuddering over 2200?
Old Oct 10, 2010 | 07:56 PM
mxracer186's Avatar
The rpms do climb nicely, it does have a tendency to backfire a bit. When the rpms get to 2200 it cuts out completely, no spuddering, then it will return to an idle.
Old Oct 10, 2010 | 10:44 PM
raydouble's Avatar
I think I would change the fuel filter.
Do you have tools to check fuel pressure?
Is the check engine light on?
Old Oct 11, 2010 | 06:01 AM
mxracer186's Avatar
It is a fairly new filter since the rebuild, but I will try that. It was throwing the tps code before I changed it but nothing now.
Blamalam
Mar 12, 2022 07:34 AM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
87toyy
Aug 4, 2015 04:51 PM
Dakotaneu
Jul 27, 2015 12:03 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
