87 22re wont rev over 2200rpm????
what a headache, i have a 85 extracab 4x4 that had an automatic trany and a 22re with a bad crank. I installed a 5spd trany and had 22re out of an 87 pickup completly rebuilt. After all the work i drove the truck daily for about a month with no problems. Now it will not rev over 2200rpms, i have replaced the tps and am some what sure it is not the problem, also tried a diffrent air flow sensor, and installed a new fuel pump and filter. hopefully some has a better ideal than me
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I see you've replaced your TPS, just curious, you adjusted it, right?
It's my understanding they can't be put in. They must be adjusted in.
Does it cut-out (like a rev box) at 2,200 like it's an electrical issue? Or is it smooth like a air, fuel or clog issue?
Starts spuddering over 2200?
Blamalam
Mar 12, 2022 07:34 AM
