86 running few seconds and dies
Old Nov 16, 2019 | 07:36 PM
Caseyslade's Avatar
It seems like everything is from the 86 I have verified the low impendiance injectors are installed that are correct it did have one high impendiance injector before. For the fuel pump I installed a gauge off the cold start injector and I get 37psi Everytime I crank the truck and it holds pressure for awhile. I will go through tomorrow and write a more detailed summary of everything I've done when I read my notes
Old Nov 17, 2019 | 10:30 AM
Co_94_PU's Avatar
https://www.yotatech.com/forums/f116...t-22re-270857/
Here you is a thread you can read through.
An additional check you can do is the fuel pump output. Attatch a 6mm clear tube to the non pressurized return to tank line off of the fuel pressure regulator, plumb the line I to a suitable container. You should get something close to 500cc/min with fuel pump running.
You could also have grounding issues with the head, this will give you poor spark.
ny hillbilly
Jan 29, 2014 12:21 PM
jeepin_junkie
Jul 9, 2013 06:44 PM
PapaChulos4U
Feb 11, 2013 11:51 AM
99 sas runner
Sep 6, 2010 06:28 PM
CoedNaked
Sep 15, 2006 02:07 PM
