86 pickup transmission swap
Old Feb 6, 2010 | 05:58 PM
rth0006's Avatar
Hey guys, I have a 1986 toyota pickup 4wd long bed. It has a 22re and its long bed and its an auto. My dad bought it brand new and now it has 498,000 miles!!! Anyways, the auto tranny is goin out, so I got a 5 speed to go in it. I have the transmission, transfer case, slave cylinder, flywheel, and i'm gonna get a clutch kit. I assume the clutch kit will include throwout bearing, pressure plate and of course the clutch. Do I need anything else, and how long/hard will this project be?
Oh yea, do you know where I can get the clutch/gas/brake assembly and pedals?
Thanks in advance,
Ryan
Old Feb 6, 2010 | 06:13 PM
waskillywabbit's Avatar
Clutch kit should have everything you need.
Clutch MC and clutch lines. Hardest part is swapping the pedals and getting the clutch MC holes cut.
Take you a day, maybe two.
Old Feb 6, 2010 | 06:42 PM
dntsdad's Avatar
lots of guys parting those out in the classified section here. SHould be pedals available in there.
https://www.yotatech.com/forums/f91/
Old Feb 6, 2010 | 06:45 PM
dntsdad's Avatar
Driveline length will be an issue as well I would think. May want to measure someones manual from the year and see.
Old Feb 6, 2010 | 06:56 PM
rth0006's Avatar
The truck that the tranny came out of is the exact same body style and same motor truck. Would it still be a difference?
Old Feb 6, 2010 | 07:40 PM
allnmstkn313's Avatar
Lengths only vary by about 3/4's of an inch.
Slip yoke should allow for this without any problems.
Old Feb 7, 2010 | 07:35 AM
rth0006's Avatar
Do I need a new brake master cylinder and booster with this swap?
Old Feb 7, 2010 | 07:39 AM
dntsdad's Avatar
You shouldnt. I cant see why.
I just changed from manual to auto oddly enough and my driveline difference was about 3". Too much to work. I had to source a driveline from an auto truck and it bolted up.
Old Feb 8, 2010 | 06:51 AM
rth0006's Avatar
Alright guys, just an update. We're going to attempt the swap saturday. As of right now I've just got to find the pedal assembly in time, or it won't be complete. Hopefully I can find a junkyard and get it all worked out. Thanks for all of ya'lls help!
Ryan
Old Feb 8, 2010 | 07:46 PM
rth0006's Avatar
Hey guys, can you tell me what the gasket is called that I need to go between the transmission and the motor?
Thanks in advance,
Ryan
Old Feb 19, 2015 | 01:00 PM
Chumlee780's Avatar
Automatic parts from swap
Do you still have the flex plate spacers and bolts I need one to put my 88 back together it needs to be a six hole flex plate
94whiterunner
Sep 22, 2015 07:25 PM
DjShiznit
Jul 5, 2015 11:51 PM
ACZR
Jun 23, 2015 07:55 PM
quaale94TRD
3.4 Swaps
Jun 23, 2015 10:27 AM
ryangs
Nov 15, 2002 07:50 PM
