86-95 Toyota truck frame.
Old Jun 11, 2015 | 03:47 AM
WhoahTakeItEasy's Avatar
Are the 86-95 Toyota truck and 4Runner frames made out of steel? I read somewhere that they we're made out of aluminum. Is this true?
Old Jun 11, 2015 | 03:49 AM
dropzone's Avatar
Fossilized
steel, no aluminum
or try a magnet
Old Jun 11, 2015 | 03:59 AM
Terrys87's Avatar
Also the dimensions are different between the 88 and older and the 89 and newer. Looking at them they look the same. My local salvage yard was able to look that up for me.
Old Jun 11, 2015 | 04:08 AM
Originally Posted by dropzone
steel, no aluminum
or try a magnet
So since the frames on the 86-95 Toyota trucks and 4runners are made out of steel is it safe to weld on them?
Old Jun 11, 2015 | 04:13 AM
Terrys87's Avatar
I am not a welder but there are several threads where people weld on them all the time for replacing rusted sections to adding in a solid axle.
Old Jun 11, 2015 | 06:36 AM
Janos01's Avatar
steel, no aluminum
or try a magnet
All 2nd gen trucks & 4runners are body on steel frame. Regarding your question, I would see no reason why you couldnt weld something. What are you trying to do?
Old Jun 11, 2015 | 11:29 AM
So 3rd Gen (86-95) Toyota trucks and 4runners don't have a steel frame? I will be buying one and doing a solid axle swap or maybe one ton axle swap and possibly a engine swap.
Old Jun 11, 2015 | 07:02 PM
v_man's Avatar
They all have steel frames , that's why searching for rust is such a big issue when buying a used Yota...
Weld away on the frame , try to get the metal as bare as possible though ... some of my welding adventures / repairs on my truck...
https://www.yotatech.com/forums/f116...repair-289109/
https://www.yotatech.com/forums/f116...better-275720/
Old Jun 12, 2015 | 05:26 AM
Terrys87's Avatar
I seen you created another thread on steel frames. I deleted your newest one. Please create only one thread for the same subject.
Old Jun 12, 2015 | 02:01 PM
superex87's Avatar
Fun fact through, many land rover defenders came with an aluminium frame.
Old Jun 13, 2015 | 11:39 PM
Do the 78-83 and 84-88 Toyota trucks have a steel frame? If so which frame is the strongest of all these trucks?
Old Jun 14, 2015 | 12:11 AM
wyoming9's Avatar
Red face
You would need to look at them all one by one!!!
Old Jun 14, 2015 | 11:35 AM
Robert m's Avatar
Jesus man, ALL TOYOTA PICKUP FRAMES ARE STEEL! Pick a body style you like, and buy one. Doing 1 ton axles and an engine swap will be just about the same amount of work on any of the frames.
matrad
Aug 26, 2024 08:21 AM
merc1100sc
Jun 26, 2015 05:24 PM
dok4runner
11
Jul 2, 2002 10:33 PM
