86 4runner transmission question
Old Sep 26, 2010 | 04:01 PM
ochs99's Avatar
I have a 86 4runner with a auto transmission. I am replacing the throttle/kickdown cable. I have the cable loose on the topside off the intake and have gotten the single bolt out that attaches it to the transmission, but how do you get the cable out? It is obviously hooked to something in there, do I have to drop the pan to get to it?
Old Sep 26, 2010 | 04:12 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Have you looked at an FSM or Chiltons manual?
Here's another place you can look: http://www.google.com/search?q=remov...-8&sa=N&tab=iw
Sorry I can't help, my AT trucks are not here right now.
Old Sep 26, 2010 | 05:22 PM
myyota's Avatar
You have to drop the transmission pan and disconnect the shift cable from the throttle valve in the transmission. You can`t just unbolt it and pull it out, its not that easy.
Old Sep 26, 2010 | 08:43 PM
ochs99's Avatar
ok, great!
at least I have somewhere to begin. So drop the transmission pan and then I can access the end of the cable from there?
Old Sep 26, 2010 | 09:03 PM
myyota's Avatar
Originally Posted by ochs99
ok, great!
Yes, you will be able to see were its connected, it would also be a good time to replace the transmission filter if it hasn`t been done in a while.
Why do you need to replace the shift cable, did it break ?.
Old Sep 26, 2010 | 09:54 PM
ochs99's Avatar
had a bit of a fire and it got kinda crispy. Although thinking back never really had a kickdown before so maybe it was messed up already. Working on replaceing vacuum lines as well, tough time finding ones that actually fit tight.
Old Sep 26, 2010 | 10:01 PM
myyota's Avatar
That sucks, what caused the fire ?.
Old Sep 27, 2010 | 10:24 AM
ochs99's Avatar
totally my fault, didn't have the fuel line completley tight after changing fuel filter. I know I checked it at least twice, but really doesn't matter now. Got it running again and dropped the pan and removed the cable. Still have a few vacuum line questions on where they go.
Old Sep 27, 2010 | 10:48 AM
myyota's Avatar
What vacuum lines do you have questions about ?.
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
Cplmike
Jul 8, 2015 08:47 PM
