'86 4Runner Leaf spring assembly question
Old Apr 12, 2015 | 10:43 AM
vikinghug's Avatar
Thumbs down '86 4Runner Leaf spring assembly question
Hey guys, first post, so hello everyone!
I'm new to this, it's likely that I have a lot to learn, and have many misunderstandings. I've had an 86' 4runner for almost a year now. I believe that the previous owner installed the Rancho Add-a-leafs, but am looking to confirm. I also believed that he installed them incorrectly. Could you please help me identify what to do here?
I have attached a photo album below.
The right side is the leaf-spring re-assembly I performed yesterday. Putting what I believe to be the Add-a-leaf above the stock bottom helper spring... Where as on the left side (the previous installation) it is below the bottom helper spring, and causing a drastic sag.
Are any of these assumptions correct? Which is the right way to re-assemble my leafs?
https://imgur.com/a/nHv9t
Old Apr 12, 2015 | 10:57 AM
dropzone's Avatar
Fossilized
yes, i think you are correc that the right side spring is set up correctly with the overload spring being on the bottom of the spring back.
that being said, Toyota hasn't gotten rear springs right in 4runner's since day one and they all have a saggy butt. They even had a recall for rear springs on my 05 tacoma.
Your springs are pretty much beat, i would recommend replacing them with some like a set of OME (old man EMu)
or you can band aid it and search the Zuk Mod...some people have reported good results on it...tons of threads on it.
Old Apr 12, 2015 | 11:01 AM
vikinghug's Avatar
Thanks dropzone! I was searching for the OME springs earlier today, without any luck. Do you have a link that could point me in the right direction?
Old Apr 12, 2015 | 11:19 AM
dropzone's Avatar
Fossilized
here is a pic of an overload spring set up on a newer tacoma
i 1986 4Runner OME springs and a ton of stuff came up
i bought stuff from these guys before, great service
http://www.lowrangeoffroad.com/1986-...ion-parts.html
Old Apr 12, 2015 | 02:22 PM
vikinghug's Avatar
Thanks man. The problem I ran into when Searching earlier was not knowing what I was actually looking for. So the results were overwhelming. I appreciate you sharing the link, it really helps.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
Nickdigg
Jul 7, 2015 06:04 AM
