85 yota 22re fit in 92 yota 22re????? HELP
Old Jun 25, 2011 | 04:20 PM
chevychevy33's Avatar
will a 1985 toyota 4x4 22re motor fit in my 1991 toyota 4x2 22re???? is there anything im going to have to change or will this be a direct hook up???? i heard fuel lines and plugs were different but im not sure. please help now so i dont have to swap stuff over while motor is in truck :wabbit2:
Old Jun 26, 2011 | 12:13 AM
wyoming9's Avatar
Smile
The basic engines are the same there are sure to be some differences if you use the electronics off the engine now in the truck it should make it some what easier.
Old Jun 26, 2011 | 04:48 AM
worshipmentor's Avatar
One obvious difference is the throttle body inlet. Early models turned down a little, later ones came straight out. I would also remove every sensor and fitting from the block/head/intake and swap them from the 91 to the 85.
Old Jun 26, 2011 | 11:51 AM
Turd Furgeson's Avatar
Just swap your intake manifold (with injectors and sensors) and exhaust. Maybe distributor too,I don't know if there was a difference in those. Basically you just want to swap the long block part of it.
Old Jun 26, 2011 | 01:19 PM
wyoming9's Avatar
Smile
I think electronics pretty much covers all those sensei thingys:jessica:
redneck17
Oct 29, 2015 09:09 PM
BeMiceElf
Oct 10, 2015 09:40 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
yourrealdad
Jul 21, 2015 11:13 AM
