5 days good then overheat...
Old Apr 9, 2007 | 06:53 PM
toyota_mdt_tech's Avatar
Problem shopwed up agter the headgasket replacement? I ask because if the headbgaskets were placed on the wrong side, it does just that. Will slowly overheat.
Old Apr 9, 2007 | 07:01 PM
thegreydog's Avatar
HG was correct and it was running great for a week, even on 50+ mile trips. We found gunk in the head when we pulled it off. You could tell he poured some stop leak in there. I figured the radiator got clogged in the process. So it was replaced and now this... my luck...
Old Apr 9, 2007 | 07:18 PM
thegreydog's Avatar
Tried to let it run a little while... but it sounds like it is about to shut off. Almost like the idle adjustment is turned all the way down.. any ideas?
Old Apr 9, 2007 | 07:23 PM
4Crawler's Avatar
Originally Posted by thegreydog
Couple of questions... Unhooked the temp sensor on the thermostat housing and the temp is non-changing, should it not send a different reading to the gauge. The reason I checked is that the plug on top does not go all the way down. Also, should the radiator sound like it is boiling after a 5 minute drive?
Because the gauge temp sender is not on the top of the t-stat housing. Down on the side of the head, between a couple of intake runners.
And it is always a good idea to find out why the head gasket failed in the first place and fix that. I've found that a failed HG is usually a symptom of some other problem. Sounds like yours is a partly clogged radiator.
Old Apr 9, 2007 | 07:54 PM
  #25
thegreydog's Avatar
Wow! I want to thank everyone who chimed in, you guys kick ass!!!! I ran it down the road and just kept running it, finally, whatever had water on it or in it, disappeared. Guys I have to tell you, for now, all of my problems went away. The bad vibration at idle, the overheating, everything, the truck is running smooth. All I can say is wow! I thought this would never end, thanks a billions. The radiator was the culprit!!!! Damn the radiator!!!
Old Apr 9, 2007 | 08:04 PM
  #26
MudHippy's Avatar
Old Apr 9, 2007 | 08:34 PM
  #27
thegreydog's Avatar
Yes sir... and your comment calmed me down so check unplugged and plugged elec. stuff and then hauled ass. All of a sudden.... viola! Thanks again!!!
Sleaker
Aug 26, 2020 06:03 AM
Colington
Mar 8, 2020 09:51 AM
Kluch8651
Jul 9, 2015 10:39 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
