5.29's and 37's questions
Old Jan 4, 2007 | 05:34 PM
switchhoodrider's Avatar
i have a 90 sas'd witha new motor and 5.29's and 9 inches of lift and run 37's just fine, and i do good on gas mileage, i am gonna bring mine down abit cause it's too tall though, i am also thinking about running 36's too depending on if i rub with i bring it down to 6 or 7 or 8 inches of lift. it's one of those personal preference type of things, i ran 35's with stock gears for a while and it did just fine for me, and i love my 5.29's and 37's
Old Jan 4, 2007 | 06:58 PM
Flygtenstein's Avatar
As for overdrive, I am not sure.
I have not spent much time cruising at highway speed.
My truck, with an auto, DD's decent. It doesn't start or go fast and I would be lying to someone if I said it drove stock.
Old Jan 4, 2007 | 07:10 PM
AH64ID's Avatar
Originally Posted by mt_goat
I thought it was a big jump going from 31's to 33's. Now that I have a little more power I'm considering 35s but I'm worried about balancing issues (the tire jocks are already having a hard time), even more rotational mass (stopping is important too), raising the center of gravity (rolling looks like a real bummer), fuel economy (I'm cheap).
My 35 BFG's have no issues with balance, and are super smooth on the fwy...
Old Jan 5, 2007 | 06:10 AM
mt_goat's Avatar
Yeah it's probably more of a "tire jock excuse for sloppy work" than a reality. They sure like to use it though. I always tell them I've been running BFG mud-t 33's for 8 years and they always ran smooth before. Then when they see I'm not going to give up and go away, they somehow manage to get them to balance out on the 2nd or 3rd try. Funny they always spend twice as long balancing the front tires as the rear, so I go straight home and rotate the back to the front and check the rears on the front. If they shake the steering wheel I go back and have them rebalance the front again. It's a PITA and usually takes half a day to get 4 big mud tires balanced and running smooth.
Adrian, so are you trailering your rig around now?
Old Jan 5, 2007 | 09:36 AM
  #25
Trailering? Ha!
I am back to school working on a Master's. This means driving about 30 miles a week almost always around town. I have not yet fixed my tach from the engine swap, so I am not sure what RPM's I am turning.
You have a SC with fuel work and a stick, right? I would be worried with 35's that you may not be able to load the charger enough.
Old Jan 5, 2007 | 09:47 AM
  #26
mt_goat's Avatar
Nope, auto....load it with what? Fuel?
Old Jan 5, 2007 | 07:08 PM
  #27
AH64ID's Avatar
S/C's take rpm's to operate, and to get optimal boost you may be at too low of a rpm in OD with 35's to take full advantage of it without having to downshift... thou with your 5.29's you would probally be fine...
Old Jan 6, 2007 | 04:54 AM
  #28
Injohneer's Avatar
Dale, where are you getting the work done?? Same place or different places?
I had Sam's Club (the big one by Quail Springs Mall) put on my 33s about 3 years ago, and have had no trouble with balancing issues.
I thought I had balancing issues, but that turned out to be that bent driveshaft...another issue altogether.
Old Jan 6, 2007 | 05:32 AM
  #29
mt_goat's Avatar
Ok gotcha.
Thanks for the tip John, that's very close to me.
Old Jan 6, 2007 | 06:03 AM
  #30
BigBluePile's Avatar
Wow, lots of info for you there drew303. If you REALLY want to run 37's and are already doing the SAS, then why not drop in a Chevy powerplant? Then atleast you won't have to run 5.71's!!
Old Jan 6, 2007 | 06:34 AM
  #31
mt_goat's Avatar
I'd take the 5.71s anyday over a Chevy I ran 5.71s for about 45,000 miles they were great with the 3.slo.
Old Jan 6, 2007 | 12:10 PM
  #32
drew303's Avatar
Yes, lots of great replies =)
So far the plan, which was the original is the one I'll keep. 35x12.5R15 mud rovers. I don't like the idea of running them on the 15x8 alloys i have now but I've seen it done with great success. Buddy of mine that works at Schwabs said its a PITA to mount 12.5's on 8" rims but it's fine. the pain in the butt part being it's his job and the tougher the mount, regardless, the more its avoided =P
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
