4x4 will not engage
Old Dec 5, 2011 | 10:46 AM
90_4x4's Avatar
4x4 will not engage
Hello I'm new here anD my 4wd will not engauge on my 1990. Even when I swap the two vacuum line around on the diff it still doesnt work. Now on the passenger firewall there are the Vsv valves and then after the three in a row valves I also have another right next to them that has vacuum lines that are 3 way connections. I'm assuming vacuum isn't reaching my diff because it didn't engauge when I swapped vac lines. So what is this other valve?
Old Dec 5, 2011 | 11:12 AM
4Crawler's Avatar
http://www.off-road.com/trucks-4x4/t...tem-19259.html
Check for plugged lines and vacuum fittings.
Old Dec 7, 2011 | 12:32 PM
90_4x4's Avatar
Got it all figured out a few vacuum lines were swapped around in the engine bay.
Old Dec 7, 2011 | 12:51 PM
4Crawler's Avatar
Yep, that is the most common problem cause that I have heard. Shop or PO works on engine, disconnects some lines, hooks them back up and engine seems to run fine so they call it good.
westonian18
May 1, 2020 06:38 AM
mussy01
Dec 13, 2016 08:20 PM
defrag4
Jul 31, 2015 10:50 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
jgwerth
Jul 16, 2015 03:23 PM
