4x4 indicator switch
Old May 27, 2018 | 07:51 AM
tbob69's Avatar
working on a 91 toyota pickup. the 4x4 indicator switch had two wires coming out and one came out. bought new switch but has no wires coming out just female plug. cannot locate a male plug to buy.
Old May 27, 2018 | 08:15 AM
RAD4Runner's Avatar
You sure you got the correct replacement part? How about the mating connector on the harness? What does it look like?
Old May 27, 2018 | 08:32 AM
tbob69's Avatar
the mating connector on the other harness was missing.
Old May 27, 2018 | 08:37 AM
scope103's Avatar
It IS the correct part. (Toyota # 84222-35070, Dorman 600-554 https://www.dormanproducts.com/p-45330-600-554.aspx ) The connector matches the EWD. (By the way, your switch has a MALE connector. You compare the metal part to the, uh, male characteristic. )
You're looking for a female connector. Do you think you have a FrankenTruck where someone cut off the connector? Where/how did your prior switch connect?
Old May 28, 2018 | 06:31 AM
tbob69's Avatar
Looks like somebody did cut off the connector. Was hoping it was there so I can just splice in with longer wires from harness.
truckeeyay
Jun 2, 2011 02:39 AM
kakariya
Mar 18, 2010 08:53 PM
cadman
Dec 11, 2007 12:45 PM
cadman
Dec 7, 2007 07:30 PM
marshall440
Nov 7, 2006 11:15 AM
