4WD not engaging
Old Jun 9, 2007 | 11:59 PM
tktmsa's Avatar
4WD not engaging
94 4wd 4runner 3.0 5speed - auto hubs.
Need a little help in starting to solve this problem, I'm not getting any 4wd.
No dash lights, no hopping/bucking on pavement (H4 or L4) I do hear a switch click under the dash when moving to and from H2wd-H4wd. But thats about it.
Where would I start?
tk
Old Jun 10, 2007 | 12:01 AM
DeathCougar's Avatar
VSV for 4wd
Old Jun 10, 2007 | 11:40 AM
eric-the-red's Avatar
This might help
http://toyota.off-road.com/toyota/ar....jsp?id=399612
Old Jun 10, 2007 | 11:53 AM
bruzer's Avatar
Sounds like the actuator or the vacuum lines leading to it. I would start with the silenoids and work your way down from there looking for any leaks. You might try taking off the vacuum line on the passenger side of the selenoid and see if there is any suction when the truck is shifted into 4 wheel drive.
Old Jun 10, 2007 | 03:08 PM
tktmsa's Avatar
Found a loose hose coming from the bottom of the little canister looking thing on the firewall side of the VSV assembly. Can't see anything obvious it could attach to. It's not sucking or blowing either in 2WD or 4WD.
Here's a pic
Old Jun 10, 2007 | 03:28 PM
bruzer's Avatar
There is also another canister just on the other side of that fender up in the wheel well. I think you might have to remove the plastic wheel well thingy to see it and make sure that has both vacuum lines running to it.
Old Jun 11, 2007 | 07:39 AM
1yotafamily's Avatar
I have a 1993 SR5 p/u with the same configuration and with the same problem. Would your help to tktmsa apply to me also?
Old Jun 11, 2007 | 08:36 PM
tktmsa's Avatar
While following some vac lines I found an interesting issue: Do you think 1/2 inch hole in the front differential would be causing some problems?
tk
Old Jun 11, 2007 | 08:51 PM
Here's a pic
Attachment 67305
That piece you circled is your VSV for the ADD system.
And define a 1/2" hole....where is said hole?
Old Jun 11, 2007 | 09:08 PM
tktmsa's Avatar
Lovely hole is in the front carrier cover, low. How hard is finding that part going to be?
kawazx636
Oct 6, 2021 03:03 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
beltcutter
Sep 30, 2015 06:14 AM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
