4Runner won't shift into second gear unless I let my foot off the gas pedal?
Old Dec 14, 2015 | 07:41 PM
Zealous84milo's Avatar
I have a 1994 Toyota 4Runner 4x4 and has some transmission issues.
Basically, happens every now and then. I push the gas and it will not shift unless I let go of the gas pedal. Also, when I let go of the gas pedal, it makes a weird whining noise. Very loud. However, if I disconnect the battery and leave it like that for a couple of days, the problem goes away but will soon return.
What made me start having these issues is when I replaced the transmission fluid because it was black. I did a fluid and filter change. Everything was done correct as can be. I even put fully synthetic.
Old Dec 15, 2015 | 08:38 AM
Janos01's Avatar
First off, is this the original transmission or a replacement? How many miles are on it? Has it had regular service thru its life? Are there any codes? Are the gears slipping while accelerating or is the car not moving at all when you press the gas?
Not to be negative, but its probably acting up because you changed the fluid and filter. After market fluid in some cars can also cause issues as well. For any high mileage transmission, if it has not had regular service through its life, it is not wise to change the fluid as it could cause issues. Rule of thumb, if it has high miles and it is working normally, "do not mess with it".
If you are still currently having issues, I would take it to a transmission shop or a Toyota dealer to see what it could be.
Old Dec 15, 2015 | 09:01 AM
scope103's Avatar
You probably have the A340h (check your door pillar), which has built-in diagnostics. I would be surprised if they would catch a truly intermittent problem, but by all means check them before you go to a shop.
http://web.archive.org/web/201408161...31diagnosi.pdf
Old Dec 15, 2015 | 03:07 PM
Yes it is the original transmission. Has probably never been serviced maybe once or twice in its whole life.
Old Dec 15, 2015 | 03:08 PM
The torque converter came out.
spiewaker
Dec 16, 2015 01:10 PM
128keaton
Oct 4, 2015 05:36 PM
Rcbc92
Sep 26, 2015 03:00 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
