4Runner tail light covers?
Open the tail gate - there are 2 10mm bolts by the on the inside of the tail lights. Undo these and gently pry the whole lens assembly towards the outside - there are little round metal connectors that sometimes seize/corrode into the lense - if you pry too hard you will crack the lens.
you will feel them come undone - and the harness assy can be seen going into the rear of the lens assy. you can now twist the bulbs out!
Hope that helps....couldn't find any pics to show you.
Good luck!
Good luck!
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
