4runner rear tailgate interior panel mounting clips
Old Jan 13, 2018 | 09:51 AM
se7enine's Avatar
Right click copy and paste works for me as does the image icon above. I haven't tried on my phone but on PC it works for me.
Old Jan 13, 2018 | 12:01 PM
Melrose 4r's Avatar
5 Year Member
When i hit the picture icon, it used to open another app that let me upload a photo from the ipad. Not anymore. The problem may be with my ipad as its been giving me lots of problems freezing up and crashing apps since the last OS "upgarde".��
Old Jan 13, 2018 | 02:09 PM
wallytoo's Avatar
my ipad only has this issue on yotatech. exactly as melrose describes.
Old Jan 13, 2018 | 03:34 PM
Melrose 4r's Avatar
5 Year Member
I think we are going to have to complain in a different thread, There must be one about site problems somewhere here.
The app seems to work normally from this PC, though.
Old Jan 13, 2018 | 03:41 PM
  #25
Melrose 4r's Avatar
5 Year Member
Here's the parts I received in the mail from ToyotaPartsdeal.com. Something must get lost in translation in order to call a screw and washer a "hook fastener".
So even though I ordered part 04023, 04155 arrived. No problem- they work correctly.
Old Jan 13, 2018 | 03:45 PM
  #26
Melrose 4r's Avatar
5 Year Member
After taking out the old screws, they just didn't look good enough to go with the new tailgate panel from McClean Metalworks so I had to wire brush and paint them.
That Krylon is fantastic paint.
Old Jan 13, 2018 | 03:50 PM
  #27
Melrose 4r's Avatar
5 Year Member
I wound up two screws short and had to improvise in each lower corner. I forgot a previous owner had put two non-Toyota screws in an attempt to secure the rear panel.
Still, it looks much, much better. The holes in the new panel are countersunk so I may look for some screws that are a bit more decorative to finish it off.
Old Jan 15, 2018 | 12:29 PM
  #28
Melrose 4r's Avatar
5 Year Member
I wasn't happy with the two non-matching washers on the corners so I started searching for replacements.
i found a couple nearly the same from a guitar amp I had apart. Nearly a perfect match. Ha!
Old Jan 15, 2018 | 12:46 PM
  #29
coryc85's Avatar
That is a very nice tailgate skin, can you say more about it? Is it powder coated steel?
Old Jan 15, 2018 | 12:50 PM
  #30
RAD4Runner's Avatar
Originally Posted by Melrose 4r
... i found a couple nearly the same from a guitar amp I had apart. Nearly a perfect match. Ha!
Yeah, those countersunk washers are nice!
Attached Thumbnails 4runner rear tailgate interior panel mounting clips-20170624_141556.jpg
Old Jan 15, 2018 | 01:49 PM
  #31
Melrose 4r's Avatar
5 Year Member
It's plastic, basically cutting board material. Contact McLean for pricing and delivery
http://www.toyota-4runner.org/classi...l-upgrade.html
Old Jan 15, 2018 | 01:52 PM
  #32
Melrose 4r's Avatar
5 Year Member
Ha! If it was a Fender tube amp like yours I would feel bad about robbing the parts. It was a yardsale Synsonics 6" practice amp.
Old Jan 15, 2018 | 01:57 PM
  #33
Melrose 4r's Avatar
5 Year Member
Is there a "show off your guitars and amps thread"?
Old Jan 15, 2018 | 02:19 PM
  #34
wallytoo's Avatar
you could start one....there are "vehicle and home entertainment" and "off-topic" sub-forums...??
Old Jan 15, 2018 | 02:25 PM
  #35
Melrose 4r's Avatar
5 Year Member
completely wiped my ipad's brain and rebuilt it last night. Not crashing or freezing anymore but still won't upload photos using the picture icon as Wally showed.
Old Jan 15, 2018 | 02:33 PM
  #36
wallytoo's Avatar
yeah, mine still won't upload via the image icon.
Old Jan 15, 2018 | 03:47 PM
  #37
RAD4Runner's Avatar
I think Corey already started one. Mine was just an 80's 6-watt Fender Champ, and since I don't play it that much, and it's pretty easy to find CBS amps, and I like minimizing clutter, I sold it. I'll buy again when I feel like playing a lot. However, I'm keeping my 1982 Transparent Cherry U.S. Stratocaster.
Try using the "source" option guys... Not too hard to do. That's how I embed my Google photos.
https://www.yotatech.com/forums/f92/.../#post52383645
Old Jan 15, 2018 | 04:03 PM
  #38
old87yota's Avatar
Here is Corey's Thread: Show me your guitars, amps, and pedals
Old Feb 23, 2020 | 10:28 AM
  #39
DocJoe's Avatar
What size are the holes for the plastic fasteners?
www.Clipsandfasteners.com has plenty of "nylon expansion nuts" to replace those. Just need to know pane hole size, size of screws, thickness of panel where nuts will be inserted.
I got nylon nuts (http://www.clipsandfasteners.com/Nuts_Nylon_s/126.htm) and trim screws (http://www.clipsandfasteners.com/sea...unk+trim+screw) to replace my much hated hidden fasteners on door and interior body panels.
what size is the hole the fasteners pop into? I’d like to get some from that clips and fasteners site
thanks!
yotes86
Jul 9, 2016 09:11 AM
toyfordlover
Jun 14, 2015 11:55 AM
gixxer_grand
Aug 8, 2007 04:15 PM
gixxer_grand
Apr 8, 2007 10:23 PM
Heebz
7
Feb 22, 2005 07:38 PM
