4" IFS lift found
Old Nov 13, 2006 | 05:53 PM
  #41
AH64ID's Avatar
Originally Posted by suprathepeg
4" bracket lifts are usually not up to the wheeling that your leaf rear will be. Why go through all the trouble to swap rear springs and not SAS the front? Bottom line there are much better ways to lift the front then a bracket lift and much better ways to lift the rear then a leaf swap. but hey, whatever floats your boat.
Have you ever wheeled a bracket lift? It sounds like not, and your just quoting others. My braket lift has taken severe abuse from a locked 56" leaf rear on 33's and 35's, on both my p/u and my 954runner. I have never had a single issue with the front end, not even alignment issues. I only started carrying a spare CV when I went to 35's, and then only when many many many miles from home. Sure a SAS is much better for rocks, but a bracket lift is a great go between and with the propper rear can go many many places.
As far as the rear leaf swap, its an economical and wise choice. It provides more flex and stability that the OEM setup. A true 4-link would be sweet, but a MAJOR PITA to design, and install. A 3-link alleviates the need to move the gas tank but is still a HUGE PITA. Leafs are simple and effective.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
