4:88 gears and 31" Tires?
Old Jun 4, 2009 | 04:03 PM
buckz6319's Avatar
Originally Posted by UpInSm0kE
Just wondering if anyone is running 31" tires and 4:88's? I am running 30" tires right now and 4:88's and it is screaming down the freeway at 55mph (Around 3K RPM). If I were to go with 31" tires would it make that big of a difference and correct the speedometer? right now the Speedometer is about 5-7 mph off. Thanks in advance.
I'm running a stock 95 4runner 4x4 automatic with stock (gear code G144) 4.88 gears and stock 31.50 and the truck gets on down the road with out any problems, except that the truck will shift in and out of O.D. quite a bit while driving.I average 18mpg to and from work round trip 50 miles includes stop and go traffic and some speeds at 55-60.I can run 65 mph at about 2500 rpms on a flat road but when going up in elevation the O.D kicks in a lot so maintaining speed some times sucks
I really don't know much about gearing but I have been told that 4.88s are a nice set up? what do you floks think?
Dwayne
Old Aug 27, 2009 | 11:12 AM
qdude79's Avatar
To resurrect this thread, I want to pose a question:
I have a 22RE with an automatic (shoot me, I know). It came with 255's and 4.56 gearing. I went up to 31's for style on fire roads. Typical Toyota gear charts tell you that 31's go great with 4.56's, but that's with a manual trans with an OD ratio of .85. My auto has an OD ratio of .69 (A44D). When I use the 4lo.com gear calc, it seems like I should be WAY above 4.88's to get back to a "usable/economical Toyota" rpm band on the freeway. Will someone please check my math???
PS- Runnin' about 3k rpms at 75 on the freeway now, with the 31/4.56 combo. Lucky to get near 18mpgs.
TIA
Old Aug 27, 2009 | 12:46 PM
mrvoodoodaddy69's Avatar
This may help some of you with tire size,gears and rpms
http://www.4wheelonline.com/superlift_tiresize.htm
also this one can help with speeds and ratios also
http://www.grimmjeeper.com/gears.html
Old Aug 27, 2009 | 12:56 PM
thunder_hamilton's Avatar
4.56?
Old Aug 27, 2009 | 01:18 PM
  #25
qdude79's Avatar
Voodoo- Thanks for the 4wheelonline link. Makes sense (the math part) but I notice it lends itself to the V8 rig, operating at low 2k's at 65 mph. My little 4 banger, of course, needs to run more rpm's, but I'm not sure how much... especially given the mods. Would 3000 at 65 be a good guess?
Once I get some opinions for the 22RE's "sweet spot range" for highway rpms, I'll be able to get some idea of gearing.
Old Aug 27, 2009 | 06:57 PM
  #26
Matt16's Avatar
Just forget about the "economy" band on the chart... maybe with the V6 engines, but with the 4cyl, you need all the gearing you can get, otherwise, you will be driving full throttle to keep it moving, and that burns a lot of gas.
TIA
Old Aug 27, 2009 | 08:36 PM
  #27
Stuwy123's Avatar
Drop a manual trans in there and you'd love your truck EVEN MORE!!!
I'm running 22re, 5 speed, 4.56 diffs and 31's on heavy steel rims. It's GREAT!!! My truck is my DD, so every commute gas mileage is key for me. I get 20-22 mpg with this setup. That's hammering on it at every chance I get. It's an awesome combo. Highway driving isn't the best, it drops me down to about 18-20 mpg (could've been all the gear I had in the back and all the big hills...). It will hold it's own on the highway, it holds on the hills better but still some down shifting on the big ones.
The only problem is the noise. Higher RPMs, 3" body lift and no carpet makes for a loud ride. I wear earplugs for my long highway drives.
XtraCab
Apr 12, 2020 05:25 AM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
PlayAwhile
Jul 20, 2015 11:36 AM
