3VZE Running Rich, slight high idle. LOSING MY MIND trying to troubleshoot.
Old Sep 28, 2015 | 08:00 AM
AKHeathen's Avatar
as in they touch together. you want to drain any stored memory. sometimes, it's a couple seconds or even minutes, but i've seen more and 1/2 hour should do it.
Old Sep 28, 2015 | 08:03 AM
Janos01's Avatar
Originally Posted by Longbed 90
For sure. I've already done it twice. Once two years ago, I used a universal (knowing no better) that went out in a few thousand miles, throwing a 25 and a 26. Put in a Denso, cleared it right up.
That was a year ago, if I remember correctly. I haven't put but maybe 3500 miles since then... maybe.
So, could a bad head gasket, bad cat or other bad sensors have caused the rich condition that shot my MPG and then in turn ruined the new O2? I suppose it's worth the sixty bucks to find out.
Originally Posted by AKHeathen
pull your battery cables and tape together fo about half an hour, then reconnect. it should be reset to new values and learn. if it's fixed, it should run right.
I do not think this is a Head gasket issue as the signs of one are coolant loss, milky oil and excessive white smoke out the exhaust pipe.
You do not have to remove your battery terminals to clear you current codes, all you need to do is find the fuse box (long rectangle one parallel to battery) and just pull all the small colored fuses one at a time and put them right back.
For testing for a leaky fuel injector, you may need to find a mechanic who works on Toyota's to check.
Old Sep 28, 2015 | 01:02 PM
RJR's Avatar
RJR
All you have to do to erase the ECU's memory is pull the EFI fuse for a few minutes. No need to remove battery cables or tape anything together.
Old Sep 28, 2015 | 01:59 PM
scope103's Avatar
Don't pull the battery cables, you'll lose all the radio pre-sets. Just pull the EFI fuse for 15 seconds (FSM, EG-171). That will reset the ECU.
Old Sep 30, 2015 | 05:25 AM
  #25
Longbed 90's Avatar
Didn't fix it.
Old Oct 15, 2015 | 05:06 PM
  #26
Longbed 90's Avatar
If anyone is interested, I found the source of the surging high idle. Still determining if it fixed the rich condition; I'm going to mark my mpg off this next tank of gas to see.
It was a clogged coolant hose from the intake manifold to the TB, rendering whatever idle control in the TB ineffective. The PO had used green coolant, not changed it (ever?) and the entire cooling system was full of rusty gunk. This particular little hose was the last remnant of that.
After all that headache and money, it was a $.90 hose.
Old Oct 19, 2015 | 08:52 AM
  #27
Janos01's Avatar
The positive aspect is by changing all those parts, you do not need to worry about it now and most of that stuff may have needed to be replaced anyway. The bad it was a hassle.
Otherwise, hows the car running?
Old Oct 19, 2015 | 11:05 AM
  #28
bicklebok's Avatar
Good job man!
Cplmike
Jul 8, 2015 08:47 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
