3vze oil leak sources
Old Apr 19, 2020 | 10:14 PM
wykp's Avatar
Went on a ~350 mile trip today and noticed some oil leaks underneath when I got home. Any ideas where I should look first?
Old Apr 20, 2020 | 02:15 PM
scope103's Avatar
Don't forget: gravity is not you friend. Oil that leaks from anywhere will work its way down and back, looking like a leak in the main seal.
Get a can of spray-on degreaser, hose it off with a garden hose. Get your engine clean enough to eat from. The oil should show up pretty quickly after that.
I have heard of (and experienced) leaks from the backs of the valve covers. Sometimes, just putting your hand back there is enough to tell (since they are at the top of the engine, oil there isn't as likely to have come from somewhere else.)
Old Apr 20, 2020 | 02:20 PM
wallytoo's Avatar
the second "leak" is pretty obviously coming from the pinion. a pinion seal change is in your future. i have done two of these, they are pretty easy with basic tools. buy a genuine toyota seal.
Old Apr 22, 2020 | 08:29 AM
wykp's Avatar
Would the leak from the pinion be gear oil? I did a touch and smell check and it doesn’t smell like gear oil.
Old Apr 27, 2020 | 04:16 AM
davidmc36's Avatar
Looks damp around the oil drain? And the crossmember?
If from above it would blow all over the place while running. Hose down and idle run needed to pinpoint.
737IP
Feb 28, 2013 05:14 PM
nobb
Jul 20, 2012 07:27 PM
Reaper5
Jun 14, 2012 11:20 AM
Junkers88
Aug 13, 2009 08:23 AM
