3vze HELP PLEASE
3vze HELP PLEASE
recently purchased a 91 ext cab pickup, 3.0 5 speed manual 4x4 345k on the clock, recently rebuilt transmission, new timing chain no issues at all. owned it for about a month, and now its starting to have serious issues. starts fine, idles fine runs fine, no hard idle never acts like its going to cut off nothing like that. at first it would start to sputter as i was going up an incline, up shift down shift, same issue. its as if im in the gas and also mashing the brake 20 times a second at the same time, sounds like the fuel is getting turned of and on but a weird popping sound from under the hood and backfiring. here comes the best part, it will run fine cold but once its warmed up it will start. sometimes in 5 minutes sometimes in 30. read alot on here but nobody seems to have one answer. ive already checked spark plugs, wires, replaced alllooottt of vaccum lines, ran seafoam through it. its such and on and off problem its hard to pinpoint. bring a mechanic around and itll run like a top. put me in traffic and i cant break 30 miles an hour. any help is greatly appreciated. also no check engine light, or other lights. my thermostat gauge likes to dance though
Check for codes: http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
The rest of the FSM if you need it: http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Sounds like the ECT(Engine Coolant Temperature) sensor(or ECT sendor) might be faulty. Which may or may not give you a code. If it's the sensor, you should get a code 22. If it's the sendor you won't get any codes, but the temp gauge won't work right. That's the theory anyway. Though when my ECT sensor wasn't working right, the temp gauge didn't work right either. The needle on the temp gauge "danced" around like yours is, and it made the engine run like crap. Which is why I mention it...
as far as i know timing is correct, the belt was replaced recently by the previous owner. and im trying to pull codes now all im getting is the CEL flashes really fast and doesnt stop when i jump the terminals. also ive been reading alot and i had put tap water and anti freeze in the truck about 2 weeks ago does that make a difference?
to be more clear, when the problem occurs the truck is at normal operating temperature, and either going up a hill or im in the gas. it sounds like popcorn under the hood and the ehaust sounds like im on and off the gas 4 times a second. the whole truck shakes and i cant gain or maintain speed. in any gear. i can shift into any gear and it will continue to shudder/sputter/skip. some days you can barely notice it and others i cant break 20 mph. i cant get it to show any codes jumping the wire, cel just stays solid or blinks really fast.
Good luck!
I had all of those symptoms just a couple of months ago. I have the same exact truck you do. I had taken it in to the shop to get a new distributor (cost me $600!) since mine died on me. They installed a new distributor, but it was the wrong kind. I had the same exact problems: "pinging" (the popcorn sound you describe), jerking all over, RPM wagging like a dog's tail. Thought I was going to die. They took it back and put in another new one, the right kind this time.
All this to say, there's a sensor in your distributor that can get out of whack that causes it to go crazy when it warms up. Once you get up to 3000 RPM's or so it levels out. I can't remember the name of it though. DON'T buy a new distributor unless you know for sure that's the issue, it's expensive. A mechanic would know what it's called and whether or not it's bad.
trying to rule some stuff out, if i unplug my mass air flow sensor or whatever you wanna call it the truck cuts off but if i unplug the throttle position sensor nothing happens, does that mean that its bad? also replaced the fuel filter to no result
hey guys, i finnaly figured out the problem, the other day the truck overheated and a hose busted. its a hoze that runs from the throttle body on top of the intake to the back of the intake. im unsure why a coolant line runs into the throttle body but the hose was basically petrified before it finally busted. it had been leaking and burning off the colant on the block witch is why i couldnt figure out where i was leaking water. and i guess the lack of pressure is what made the truck act funny. either way 11 dollars and a LOT of elbow grease later my issue is resolved. i hope this helps everyone out.
hello all! very sorry about no more pictures, this project has been kicking my butt. i have had alot going on and i have just today got it all back together. id like to thank everyones posts for being so much help to me. she starts and runs but will nock off if i dont keep my foot in the gas pedal. no check engine light. any ideas?????/
read this: http://personal.utulsa.edu/~nathan-buchanan/93fsm/ and buy a voltmeter to do a lot of testing. run some fuel injector cleaner.
is the check engine light working?? does it stay on while you are trying to start the truck?
