3vze Fan
Old Nov 21, 2015 | 06:33 AM
elaketiger's Avatar
3vze Fan
Is it normal for the fan to run for the first few minutes after starting. I use my truck for hunting and as soon as I start the engine and for at least 3 minutes the fan runs. The fan is extremely loud so easing out of the woods is impossible. I just seems illogical that the fan would need to run when the engine has not even warmed up yet. Thanks.
Old Nov 21, 2015 | 07:23 AM
Marc's Avatar
Mine do that. Never timed them but they turn at full speed for a bit.
If you try and turn the fan with the engine off and cold you'll see that it's engaged.
Old Nov 21, 2015 | 11:00 AM
mct75's Avatar
It should run, but not for 3 minutes. Maybe 10 seconds. The fan clutch uses a thick liquid that settles in the bottom of the clutch, locking it up until it gets all slung around to where it needs to be.
Old Dec 27, 2015 | 08:18 AM
elaketiger's Avatar
My fan has the hoop ring connected to the end of the blades. Does this type of fan make more noise than a fan without the hoop, or does it matter. It is really noisy. My hunting buddies get annoyed when I drive through the woods saying they hear my fan "roaring".
Old Dec 27, 2015 | 01:25 PM
superex87's Avatar
This is normal. The hoop does not make a difference. May need a new fan clutch. Rock auto sells new ones.
-City Slicker
Jan 5, 2016 06:54 AM
yotapwru
Washington
Oct 22, 2015 09:08 AM
JHalcyonM
Sep 14, 2015 01:10 AM
gp66
Sep 14, 2015 12:10 AM
markf1
Sep 3, 2015 01:23 AM
