3vze Engine Knock
Old Jul 11, 2010 | 12:51 PM
  #41
dasrunner's Avatar
Found my problem, #2 rod bearing had very little left but surprisingly the crank looks completely fine so im in luck only a 5 dollar part lol now i gotta put it back together
Old Aug 14, 2010 | 05:54 AM
  #42
MudsharK's Avatar
Just wondering if you figured out what the knock was? Im getting a smiliar knock, but its not half as loud as yours. Engine still running strong tho, no loss of power or anything...Im thinking on doing a rebuild when the time comes rather than a 3.4 swap...Fredericton here too.
Good luck
Old Aug 14, 2010 | 09:33 AM
  #43
dasrunner's Avatar
it chewed my #2 rod bearing to pieces so i replaced all of them. no problems thus far just makes a little rattle when its cold
Old Aug 22, 2010 | 08:51 AM
  #44
jkdunbar's Avatar
Good luck
You can pick up a 3.4 from Capital City for about $150.00 with low KM's!!!
Old Aug 22, 2010 | 04:50 PM
  #45
chad500's Avatar
I've had rods go out that didnt leave metal in the oil, just stacked the bearings. Wouldn't quieten down doing the spark plug trick either. Some will, some won't. As far as rocker arms, 3.0's don't have them, it's a shim and bucket under the cam. Toyota calls them lifters, but they are buckets, nothing to break. I'm going through a similar thing now, had an intake seat cough up on the #2 cylinder. That will cause a racket, but also a skip due to loss of compression. On your comp. check, is your engine warm and throttle wide open? On the cyl. with lower compression, pour a teaspoon of oil through the plug hole and see if that brings the PSI up, if it does, you have ring issues. If it doesn't come up, maybe HG.
Old Dec 27, 2010 | 10:48 PM
  #46
clkinaz's Avatar
A stethoscope - or long stick pressed to one's ear should help locate the sound, no?
icentropy
Sep 16, 2020 02:47 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
