3VZE Displacement Calcs
Ok, so i need someone to check my theory here.
I have a stock 3vze block that i am boring .040" over.
I was trying to figure out what my end displacement would be...
Here are my calculations.
According to 4x4wire, the stock bore is 87.5mm and stroke is 90mm. I tried calculating this out and it doesn't equal the 2958cc that is listed on the spec sheet...
Pi(Radius of Bore)^2 X Stroke = Volume of Cylinder
Pi(87.5/2)^2 x 90 =
6013.21875 x 90 = 541.189 cc per cylinder X 6 cylinders = 3247 CC Total
So i assumed the stock stroke listed is wrong and re-computed trying to find the correct stroke using a known total displacement of 2958CC.
I came up with a stock stroke of 81.986mm (not 90mm)
According to this, my oversized bore would take the motor up from 2958cc to 3027cc.
.040" = 1.016mm
Oversized bore = 88.516mm
Radius = 44.258mm
Pi(44.258)^2 x 81.986 = 504.51 cc per cylinder X 6 cyl = 3027 CC Total
You guys following me?
Remember that you need to convert mm > cm (mm/1000)
My real question is does anyone know what the stock bore and stroke really are?? either those are listed wrong on 4x4wire or the total displacement is, but i am pretty sure my math is right...
Pi(87.5/2)^2 x 90 =
.040" = 1.016mm
Radius = 44.258mm
My manual lists the bore as 87.4mm and the stroke as 82 mm. If you assume the 2958cc is correct then the new dispacement will be the original displacement multiplied by the new bore divided by the original bore, which is 2958 x 88.4/87.4 = 2992cc.
That is interesting that the manual lists the bore and stroke differently than 4x4wire, but are you sure the bore is larger than the stroke? or is it the other way around?
I wasn't actually calculating the volume, I just assumed the 2958 was correct. If you already have the volume then the new volume is simply the ratio of the new bore to the old bore multiplied by the original volume. The stroke and pi are both constant so don't need to be factored in.
And I double checked the manual, the bore is larger than the stroke. Of course the manual could be wrong.
Based on a bore of 87.4mm, and a stroke of 82mm, the displacement calculates to 2951 cm^3, which is pretty close to the quoted displacement of 2958 cm^3. Considering the bore's diameter is only given to us to 2 significant digits, and the stroke is only given to 3 sig figs, we have arrived at the correct displacement (if each measurement was given to four significant digits, e.g. XX.XX mm, we would probably get the exact right number).
So, if you add .040in to the bore, your new displacement is 3020 cm^3, or an additional 69 cm^3 (4.2 in^3). This equates to a 2.3% increase in total displacement from a 1.1% increase in total bore, further showing that the increase in volume with respect to bore is not a linear ratio.
