3vze Defect Summary
Old Feb 5, 2006 | 03:30 AM
Platypus1's Avatar
3vze Defect Summary
Okay, well with all the threads I have read between this site and others it seems like these are the 2 "Must Do's!" In order to remedy the 3vze of it's critical design flaws.
1. Head Gaskets (Source Jasper engines):
Due to head gasket failure, JASPER is using the latest updated head
gasket from Toyota. Originally the O.E. gasket was graphite on both
the cylinder block side and the cylinder head side. Due to the
bi-metal application, the block and head would expand and contract at
different rates. The scrubbing effect would then separate the
graphite from the core of the gasket causing leaks. The new gasket
has an MLS side for the head and a graphite side for the block. This
is to eliminate blown head gaskets.
2. Cross Over Pipe (Mulitple Thread Sources)
The Crossover pipe causes cylinders 5 and 6 to super heat, burning valves and adding stress to the already vulnerable head gaskets.
I have read some pretty good write ups on Downey headers. Headers relieve the back pressure stress and increase the engines performance around 14 HP.
Old Feb 5, 2006 | 06:42 AM
Morphine's Avatar
Whew, I already took care of these. thanks for posting for those new to the forums. we should make a list of "To Do's" in general.
example:
Shifter seat bushing - wears out and causes rough shiifting.Shifter seat bushing
Something like this. Break it down via model and years, and then a general "catch all". EVeryone could vote in one thread as to what is considered "NEEDED" and these items will get added. Just a thought.
-=Morphine=-
Old Feb 5, 2006 | 09:22 AM
Bumpin' Yota's Avatar
Morph - you have the jasper MLS/Graphite HGs?
Old Feb 5, 2006 | 09:37 AM
suprathepeg's Avatar
The steel slipperplate Rock gasket HG and the steel core Nitroseal are also proven solutions.
Old Feb 5, 2006 | 09:55 PM
Morphine's Avatar
Bumpin - long time, well no I don't have that for my head gasket. I just have the Toyota OE replacement head gasket, but she's holding up.
Old Feb 6, 2006 | 08:12 AM
snap-on's Avatar
Ive got a Jasper in my truck that is supposed to have "better" HG. which is one reason i went with them like 5 years ago.
It was expensive but ive love my 3.slow.
Old Feb 6, 2006 | 03:18 PM
What does jasper use?
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Matthew Perez
Sep 28, 2015 05:43 PM
