3vze crankshaft pulley!!!
Old Aug 17, 2013 | 12:57 PM
solidaxle85's Avatar
Hey guys i was wondering if anyone had any ideas on how i can get the crankshaft pulley bolt off on my toyota 3.0L
So the engine is out of the truck on a stand with no clutch or flywheel on it
I've tried to wedge pieces of wood and all that in there but no luck could anyone
give me any ideas on how i could go about taking care of this i just need to put
a timing belt on and i can throw the engine back in the truck
thanks
Old Aug 17, 2013 | 01:58 PM
slow-mo's Avatar
When I replaced my 22R engine, I had to remove the crankshaft pulley (harmonic balancer) to transfer it over to the new engine. I was told by the machine shop to heat up the bolt with a propane torch, smack the head of the bolt with a hammer a couple times while hot, and then I used a Harbor Freight electric impact gun like this one: http://www.harborfreight.com/12-in-e...nch-68099.html
The bolt came right off.
Old Aug 17, 2013 | 02:39 PM
RSR's Avatar
RSR
Use google search. You can rent tools, use chains, use rope, blocks of wood, or several other methods recommended previously on here.
http://lmgtfy.com/?q=site%3Ayotatech...t+bolt+removal
Old Aug 17, 2013 | 03:23 PM
oldblue's Avatar
invest in some tools. i picked up a 30 gallon air compressor that came with a free air tool kit from sears for less than $350 for the house a few years back. great investment if you're gonna do any wrenching at the house. with my "work" impact, the compressor will take off honda crank bolts.
Old Aug 17, 2013 | 05:24 PM
slow-mo's Avatar
I should have mentioned, I did not use anything to hold the crank pulley when I removed the bolt. However, when I installed the pulley and bolt, I had to fab up a tool to hold the flywheel still in order to torque the bolt down.
Old Aug 17, 2013 | 07:09 PM
scope103's Avatar
Don't waste time with wedges, chains, blocks of wood. Even if these worked to get the crankshaft bolt out, as Slow-mo discovered, you've still got to put it back in. You're going to have to get it to 181 ft-lbs; your impact wrench isn't even going to touch that (and if it did, how would you keep from over-tightening?)
Just make the tool, fer cryin' out loud! There are lots of very good ideas on this site. I, of course, am partial to this one: https://www.yotatech.com/forums/f116...h-3vze-137934/ . The price was right.
Kamaloha
Oct 16, 2015 05:13 PM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
EVars
Sep 29, 2015 02:06 PM
charlie_fong
Sep 27, 2015 10:06 PM
