3VZ Ignition Issues
Old Sep 15, 2010 | 01:04 PM
  #41
freddy's Avatar
Yep. the car is only running from the gas it gets from the cold start injector
Old Sep 15, 2010 | 01:21 PM
  #42
thook's Avatar
It may not be the ECU. Is the CEL illuminating when you turn the key to ignition?
Old Sep 15, 2010 | 01:26 PM
  #43
freddy's Avatar
yep...
Old Sep 15, 2010 | 01:38 PM
  #44
thook's Avatar
Good. Then, try shorting the two diagnostic terminals labeled FP and B+ located in the diagnostic port under the hood. Use a paper clip or stiff wire. This bypasses the fuel pump relay and AFM fuel pump switch circuits. See if it will run then.
Old Sep 15, 2010 | 01:40 PM
  #45
freddy's Avatar
tested,nothing tested the relays everything good.
Old Sep 15, 2010 | 01:41 PM
  #46
freddy's Avatar
the only cold start injector is working
Old Sep 15, 2010 | 01:45 PM
  #47
thook's Avatar
Test the distributor, yet? If the ECU doesn't get crank rotation feedback, it won't fire the injectors.
Old Sep 15, 2010 | 01:48 PM
  #48
freddy's Avatar
the truck start, but hesitate like crazy
Old Sep 15, 2010 | 01:50 PM
  #49
freddy's Avatar
if the distributor doesn't work will the truck have any spark?
Old Sep 15, 2010 | 01:51 PM
  #50
thook's Avatar
I understand that. But, if the Ne and/or G1 signals are lost to the ECU at any point upon ignition or running, then the ECU injector driver's will not operate.
  #51
freddy's Avatar
because it got a pretty nice one
Old Sep 15, 2010 | 01:57 PM
  #52
freddy's Avatar
ok how do you test the distributor ?
Old Sep 15, 2010 | 02:29 PM
  #53
MaK92-4RnR's Avatar
the only way I know of testing the distributor is taking the cap off and turning the key... see if the rotor spins.
UPDATE: Apparently i got a WHOLE new VAFM. I got it at whole sale cost for 182.63. It wasn't just the clip.
Old Sep 15, 2010 | 02:48 PM
  #54
freddy's Avatar
sweet, I am glad it workout for you,
the distributor turns.
  #55
freddy's Avatar
or spins..
Old Sep 15, 2010 | 03:23 PM
  #56
wmayota's Avatar
subscribed
Old Sep 15, 2010 | 03:42 PM
  #57
thook's Avatar
That's not the way to test the distributor. Here's a good start.....
http://personal.utulsa.edu/~nathan-b...12onvehicl.pdf
You're looking to test the pick up coil/signal generator.
Old Sep 15, 2010 | 03:43 PM
  #58
thook's Avatar
Ah-ha! I thought so. Anyway, good for you.
Old Sep 15, 2010 | 03:52 PM
  #59
freddy's Avatar
Sweet...THANKS...I will test it tomorrow
Old Sep 15, 2010 | 04:04 PM
  #60
freddy's Avatar
Doesn't the "Pulse" from the Distributor activate the Igniter module and then the igniter activate the coil that send electricity to the spark plugs?
