3vz failing smog no ac and code 51.
Old Aug 17, 2011 | 02:01 PM
drkblu4runner's Avatar
when i have the diagnostic connectors jumped and truck is idling it rapidly blinks like normal, however if i give it gas it gives me a code 51 and as soon as it is back at idl it goes away. tested the idl and e2 connectors on the tps and they are working. hoping that its the problen with the smog or the ac
Old Aug 17, 2011 | 05:33 PM
TNRabbit's Avatar
You don't check for codes with the engine running. Key ON after TE1 & E1 jumped.
Colde 51, IIRC is knock sensor. That would put your timing at 0 degrees BTDC.
Old Aug 17, 2011 | 07:37 PM
so thats normal?
Code 51 AC signal on; DL contact off (in trany shifter with diagnostic connector jumped)
NOT>Code 52, 53 and 55 Knock sensor fault
Old Aug 17, 2011 | 10:43 PM
Anyone els have this?
Old Aug 18, 2011 | 02:21 PM
anyone? i have already failed smog 3 times
Old Aug 18, 2011 | 03:16 PM
check vid out.... i just tried another tps without any change.. http://youtu.be/J3f56LhEdEU
Old Aug 18, 2011 | 04:55 PM
TNRabbit's Avatar
You DO know how to adjust the TPS, right?
Old Aug 18, 2011 | 05:06 PM
Yes. I have 3 4runners, 2 of them are 3.slows..the other 3.slow does not get the code 51 btw. I appreciate any help
jmoua
Mar 29, 2023 03:42 PM
accuracy
Aug 30, 2015 09:47 PM
JustToynAround
Aug 19, 2015 11:46 AM
accuracy
Aug 4, 2015 08:05 PM
Jnkml
Jul 6, 2015 01:20 PM
