33x10.5 with 5.71 Gears?
I have read a few posts where people have recommended regearing to 5.71's to run 33x10.5's on the 3vze auto. I have an auto 3vze, stock 4.88's and it is a Daily Driver, which includes several highway trips per week. Would the 5.71's be too low for highway driving with 33x10.5's? I am getting 33x10.5's but I am not sure if I should regear to 5.29 or 5.71. I don't want a super sluggish beast, but I also want to be able to do 70-75mph on the freeway in 5th (OD). Also What is the difference between/benefits of changing the entire ring and pinion gears vs changing just the third member?
I've never driven a 3.0 automatic, but I think that the gearing for the auto, that most reccomend would be 4.88s for 31's, 5.29s for 33's and so on...
The auto tranny behind the 3.slow is a 4speed btw.
Note that the lower the gear ratio, the more critical the setup. You want to have them done by someone who does it every day - not thinks they can handle it. Check out www.gearinstalls.com - hell, print it out and take it with you!
With the auto, 33's, and 5.71's you will be at 3200 rpm at 75mph, which isnt to bad... 5.29's will only yield you 2965, which isnt much different that OEM, so go with the 5.71's. The only issue I would see is that if you kick out of OD at 75 you will be at 4500+ rpms...
Update on this setup: I'm now running 5.71's, 33x10.50's, auto. It is badass. It should have came from the factory this way. It is in the power band all the time, and completely woke this truck up. The highway is a cakewalk doing 75... and It hasnt bumped out of OD yet, just pulls up hills like they are no problem.
I'm still on my first tank of gas... but i'll update mileage wise.
BtW Auburn, we need to go wheeling man. [end hijack]
). The stock 4.88 rear 3rd member has to be replaced to regear (but not the front). So my advice is get a 3rd already setup with the gears and locker you want from someone who is good at setting up gears...like ZUK http://www.gearinstalls.com/ or ORS http://www.offroadsolutions.com/meetthestaff.htm. And don't buy cheap import gears unless you want to regear often. US gear is made and heat treated in the US. Zuk I think also likes Precision gears.
I went to Auburn this past weekend from ATL... drove 290 miles with the 5.71/33 combo on 14.1 gallons. I dont know how far off my speedo is ( 10-15% would be my guess) but in my book that is still pretty good.
And I'm loving the 5.71's around town. Anyone wanna race?
The other Runner I had was an 87...22RE/auto/571/33x10.50....not as fast as the 3.0 Runner but pretty good of the line for a 22RE auto. About 3300 rpm at 75 real miles per hour(per GPS) ....revvy but the cruise control held it most of the time without downshifting. Never had a 'stall' problem on the trails I took it on. (Staceman can recall the time on the Crown King trail where I made it up the loose rutty hill with minimal probs (only had the 571's and rear Detroit) and a TJ with a front locker, bigger tires and the 4.0 engine just could not stay on the line up the hill and kept sliding around and had to carefully back down and take the Nissan route....oops, did I say that
My first experience with 571 gears was back in 1986 when I had an 84 Toyota red longbed and was one of the few 4x4's on the trail (at the time) that had Detroit Lockers both ends and low 571 gears. I used to drive that combo with 33" tires(considered to be the biggest tire any serious Toyota owner should use for the rocks) and the 5 speed to Moab Utah once or twice a year.....when the Easter Jeep Safari crowd numbered at a massive 700 people.
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
