33's or 35's?
Old Mar 24, 2007 | 06:01 AM
usmarinerecon's Avatar
33's or 35's?
I have a 1st gen 4runner and have purchaced a 5" trail master rear from wabfab and a 4" front from skyjacker. (ifs) I have brand new 33x12.50 Bfg Mudd Terrains sitting on some cragar soft 8's. the question is.... will I have enough room, look proportional, and have to do any cutting to the finders if I go to a 35x12.50? If so there will be some 33's for sale that have never hit pavement. Thanks
Chandler
Old Mar 24, 2007 | 06:35 AM
Sonofmayhem's Avatar
You probably could fit 35s, but to get better gas mileage, and vroom vroom, stick with the 33s. or post a pic with the 33s and we shall tell you other wise.
Old Mar 24, 2007 | 06:39 AM
I'm not worried so much about the gas mileage since its not my everyday driver. But the vroom vroom part hopefully was cured with the 4.88's I just installed.... so with that inmind....
Old Mar 24, 2007 | 11:05 AM
which engine? 22re or 3.0? if its a manual 3.0 i would go 35s but if it isnt then i would stick with 33s i wanna run 4.88s with 35s but i dont know if i will or not.
Old Mar 24, 2007 | 11:13 AM
Dr.Trevorkian's Avatar
bigger tires = more weight to swing, regeared or not
Old Mar 24, 2007 | 01:44 PM
MudHippy's Avatar
I'm a mud person mainly, I love my 35x12.5's. I roll right through where 33's don't want to. I need the the massive size for floatation, and ground clearence for the ruts. They also come in handy in the snow/sand or crawling around in the woods over various rocks, fallen trees, stumps, huge potholes, what have ya, that 33's would find more difficult. You get better break-over angles, departure angles, etc. so you won't be as prone to getting stuck. My point here being most dudes with 33's don't end up as far down/up the same trails I take. If you had a sraight axle that much lift should clear 35x12.5's, I have IFS with a 3" body lift and the torsion bars raised (it ends up about 4.5" of total lift in front) with 2" aals in the rear. I can make them rub a tiny bit sometimes in front, takes some effort.
Old Mar 24, 2007 | 02:10 PM
waskillywabbit's Avatar
Never go smaller.
Old Mar 24, 2007 | 02:16 PM
yodannyc's Avatar
you should go with 33's
Old Mar 24, 2007 | 04:13 PM
dijlop's Avatar
screw it, raise it some more, swap the engine for something with some pop, and throw on some 44's. or stick with 33's, whatever floats ur boat
Old Mar 25, 2007 | 05:39 PM
91ToyTrck's Avatar
I'd say 35s and 4.88s. I ran 35s with 4.10s and it wasn't bad, but the 4.88s would have been nice. I'm probably going to run 4.88s with my 33s, but I mines a daily driver.
Old Mar 25, 2007 | 05:46 PM
gus310's Avatar
i would go with 35's, and get yourself an extra cv. i mean cmon, why wouldnt you want 35's? bigger is better in this case.
