31's on a 92
Old Nov 29, 2007 | 11:03 PM
92toypunk's Avatar
Exclamation 31's on a 92
just getting ready to buy tires... and just finished putting a 3 inch upper arm in the front, and a 3 inch extended shackle... will the tires rub at all w/o glass... or can a run both glass and a larger tire...?
Old Nov 29, 2007 | 11:17 PM
stormin94's Avatar
31's WILL NOT RUB on a stock height 1990-1995 Toyota Pickup, or 4Runner.
Old Nov 29, 2007 | 11:23 PM
b.miller123's Avatar
by the way:
everyone here will assume you are running a 4wd rig, so if you aren't, then you might want to mention that
Old Nov 29, 2007 | 11:33 PM
stormin94's Avatar
Originally Posted by b.miller123
by the way:
Good point. I didn't think of that.
Old Nov 30, 2007 | 05:15 AM
tc's Avatar
tc
Is it a 4WD? If so, you should be able to fit 33x10.50 EASILY.
If it's a 2WD, you're not gonna fit 31's. I had an 89 2WD with almost 7" of lift (Fabtech long travel) and they still rubbed quite a bit
Old Nov 30, 2007 | 07:38 AM
Travisfab's Avatar
My 94 2wd only rubs when I hit something HARD. Running 31's with a custom upper arm and sway away torsions, about 4 inches of lift.
Old Nov 30, 2007 | 10:00 AM
Logman's Avatar
got 31x10.5 bf at on my 92 4x4 pickup...... no issues at all
Old Nov 30, 2007 | 10:34 AM
tc's Avatar
tc
hmmm - maybe the extra width was my problem ...
