302 swap is about to go down!
Old 04-06-2008, 09:05 PM
  #81
SledgeHammer's Avatar
Update guys. My father inlaw gave me a complete 85 Crown Vic that has fuel injection on it and a C-6 transmission. So the fun is just gettin started. The only thing is 85 was a transition year on the fuel injection. The injection on this looks like a carb. Anyone got any suggestions for this? Should I scrap the injection and just throw a carb on it?
Old 04-07-2008, 06:50 AM
  #82
Victor's Avatar
I believe what you have was called CFI - central fuel injection. It is similar to GM's TBI. I was only used for a couple of years until the Multipoint EFI began in 86. Yes you can pull that off and use a carb - I think it even uses a carb style intake manifold. I don't know what the emissions laws are where you are though.
Old 04-07-2008, 11:52 AM
  #83
So lets recap.. I have a 3.slow auto going to replace with the aforemetioned 302 c-6 combo. What route would you guys go on transfer cases and adapters? Is there no way to use the transfer case thats in it?
Old 06-04-2008, 09:42 AM
  #84
vtjeenyus's Avatar
is this swap still ongoing or what ???
I have a 1989 22re(blown) and a 1985 lincoln markvii with ford 8.8 rear w/ disc brakes
Old 06-04-2008, 08:24 PM
  #85
302Toyota's Avatar
Thumbs up 302 swap
I have a 302 In my truck i have finally got everything the way i like it i had to get an exhaust manifold from an early bronco on the passenger side so the exhaust would go striaght out the back when i bought the bellhousing conversions from NORTHWEST OFFROAD i would not recommend at all buying one of these unless you can baby you stock toyota tranny i went through 3of them it is cheaper anyways to just get a c6 or c4 or a manual which im looking for now but i must say putting a v8 in my truck was the bvest thing i have ever done to it the only thing i want to do different is put EFI but everyone wants to race and they just stare when they see your truck Spining posi 36" tires at a red light and hear it but way to put a good motor in it Ford all the way you dont have to have a body lift to clear the distrib.
Attached Thumbnails 302 swap is about to go down!-toyota-rd-2.jpg   302 swap is about to go down!-toyota-rd-3.jpg
Old 06-04-2008, 09:43 PM
  #86
Kiwipushrod's Avatar
Hey,
Enough Already, When is the 302 swap,...Gonna "Go Down"?
Have You Guys seen JD's 302?....Sorry JD
Thanks, Kiwi
Old 03-31-2009, 10:26 PM
  #87
okie's Avatar
Old 08-23-2011, 06:59 AM
  #88
Tim W's Avatar
I've got a 1990 1 ton duelly and I'm thinking about putting a 302 in it for towing and power it is two wheel drive should I buy a used vehicle to get the coumputer wireing harness etc and is the adapter plate different for a 2 wheel drive any insite will be appreciated
Old 08-23-2011, 08:14 AM
  #89
TNRabbit's Avatar
Do you have the 3vze w/5 speed?
There are several companies that make bell housing adapters for USA V-8 engines to the Toyota R150F
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Gevo
07-29-2015 11:15 AM
GeoRoss
07-24-2015 03:03 PM
Quick Reply: 302 swap is about to go down!
