in 3 ft of water????
Old Dec 21, 2010 | 09:52 PM
  #41
85toyman's Avatar
Why don't you start with putting it in the air. Try putting it into 4wd and see what happens. Post back here after you try that and see where we stand. I will do some more looking in the mean time.
Old Dec 21, 2010 | 10:04 PM
  #42
justin_4runner's Avatar
ok sounds good to me might be a couple days before i will get time to do this. as i need to find another set of jack stands,
Old Dec 21, 2010 | 10:07 PM
  #43
muddpigg's Avatar
Is it possible that when water got in that the vacuum line filled? Your local I got a set of small jack stands you can use.
Old Dec 21, 2010 | 10:09 PM
  #44
85toyman's Avatar
Sounds good, I will check back.
Awful nice of ya muddpigg.
Old Dec 21, 2010 | 10:17 PM
  #45
going to raid mother inlaws and see if they have a set, if i need more ill let you know muddpigg and if i need help i might have ask for some help..
Old Dec 21, 2010 | 10:25 PM
  #46
muddpigg's Avatar
No worries and not trying to be "weird," just trying to be helpfull. I gotta start my Xmas shopping tomorrow.
Old Dec 21, 2010 | 10:34 PM
  #47
mudd, its not a problem my wife is a little on the causious side and doesnt like people coming to the house unless we known them for a while, but if i need help she will just have to live with it and deal with people coming over.
Old Dec 21, 2010 | 10:44 PM
  #48
muddpigg's Avatar
Can't say I blame her it is a good idea since we live in the meth capital of the country. I'll probably have a kid or dog in tow. It doesn't have to be a packaged deal either. You won't hurt my feelings if you just need the jackstands. Just remember where you got them.
Old Dec 21, 2010 | 11:37 PM
  #49
peow130's Avatar
Hate to hijack, but tacoma is nothing compared to spokane when it comes to methheads/tweakers.
And spokane is nothing compare to cusick.
Old Dec 22, 2010 | 12:03 AM
  #50
muddpigg's Avatar
Nothing is a relative term.
Old Dec 22, 2010 | 09:07 AM
  #51
85toyman's Avatar
There is a reason we call it "Methford Oregon". Ha Ha. I would have to say that Modesto California would have to be right up there with Tweeker Capitol as well. I guess that it just depends on where your at and what you see when your there compared to everywhere else. Its all about context.
Old Dec 22, 2010 | 10:31 AM
  #52
muddpigg's Avatar
Unfortunately one meth head is too many and it only take one.
Was going to tell a story but we're hijacking
Old Dec 22, 2010 | 11:07 AM
  #53
85toyman's Avatar
agreed X2
Old Dec 22, 2010 | 08:49 PM
  #54
so i started looking things over and i ended up switching the vacuum lines on the front end around, and now when put into 4wd the light comes on and stays lit, so i think it might of been the air lined where backwards, just looking for something that tells me what way the lines should be on.
Old Dec 22, 2010 | 10:20 PM
  #55
85toyman's Avatar
I looked at mine and there are the two lines that come down by the frame rails.The line that is closest to the front of the rig is plugged into the line that is closest to the front of the 4runner. The line that is behind that is also the line that is behind the one on the frame. If that makes sense. Basically they mirror each other as they come down off the frame in relationship to how they plug into the two ports on the front of the diff.
However, if you switched them around and they work, then problem solved, no matter what order they come down to the diff from.
Did your 4wheel drive work before the water accident? Is this the first time you have tried it?
Old Dec 22, 2010 | 10:23 PM
  #56
85toyman's Avatar
Best way to tell. Put it into 4wd, go for a drive and make a turn on pavement. The front end should have some binding during a turn. If it drives normal, then 4wd is not working. I would bet that since your light is now on and working properly that the rest of the system is working properly.
Did you remove the hoses for any reason? I am just wondering how they got switched around to begin with...
Old Dec 22, 2010 | 10:34 PM
  #57
i got the rig a couple months ago and have not needed 4wd tell now, i did pull the lines off last week and put new vacuum lines but followed where they where before, i talked to the po and he also said it did the same to him, i did put it in 4wd and i dont really think it binded up much, but am going to still jack it up and see how all the wheels turn, i did pull the actuator couple weeks back and cleaned up to make sure it is moving, so i might have to reopen it and make sure its in the right location.
Old Dec 22, 2010 | 10:46 PM
  #58
85toyman's Avatar
The actuator really only goes in one way. I don't see how you could not put it into the right location.
I would try in 4 low and see where your at with binding. I would still jack it up and see if you got any positive tire spin on the front. As for the PO having the same problem, most likely didn't really care about 4wd and didn't want to mess with it. He bought it that way, and sold it that way.
I would still have to say that if the light now stays on it should work, assuming you don't have a vacuum line leaking issue and the front accuator not getting the suction it needs. But since you changed those lines you should be ok
Old Dec 22, 2010 | 10:52 PM
  #59
what i mean by right location is that the fork in the right location and not slipped in in the wrong spot, i have seen a couple threads about people having there's in the wrong spot so when put in 4wd it moves it a little but not all the way into location. that's what i meant..
Old Dec 22, 2010 | 10:59 PM
  #60
85toyman's Avatar
gotcha. Let us know what you find
