3.0 rebuild- runs- won't rev up- dies
Old Aug 30, 2017 | 04:10 PM
Budman1's Avatar
Still going forward....... we've got the rebuild in the 92, it starts, runs, not real smooth, but runs.....I cover a portion of the mouth of the maf, it smooths out and idles fine even when I remove the mag blockage, I can press the footfeed slowly and reach over 3000 rpm. Normal pedal pressure it will die.
we changed nothing that was on the exit engine but: new manifold cups for injectors.
What do ya'll think......are we a first?
Old Aug 30, 2017 | 06:07 PM
space-junk's Avatar
sounds like a vacuum leak, almost. or maybe the iacv isnt working properly.
Old Aug 31, 2017 | 10:51 AM
Budman1's Avatar
Thanks Spacejunk,,I'll check that first Monday morning.
Old Nov 8, 2022 | 07:16 PM
studawg66's Avatar
This sounds like textbook VAFM issue or vacuum leak. Are you 100% certain that the VAFM connection to the ECM is good and that it checks out per the FSM? After my rebuild my engine ran like you describe only to realize I forgot to plug in the VAFM. Haha. Idled fine but I had to very slowly increase throttle to get it higher without stalling. So it is likely something in that air side of things.
BlackYoder
Nov 6, 2022 02:08 PM
Bay Runner
Apr 22, 2021 03:13 PM
Rithsleeper
Jul 26, 2020 09:02 AM
mystic1219
Sep 19, 2008 01:34 PM
CC_yota
Sep 15, 2007 01:05 AM
