3.0 re-install tips.
Old Jul 21, 2010 | 05:39 PM
4runnerJ's Avatar
I just got a rebuilt engine and am getting ready to pull my old engine out, but there are a lot of hoses and what not. My question is, are there any tips out there to help me remember where all of these hoses go when I put the new engine in?
Old Jul 21, 2010 | 05:57 PM
camo31_10.50's Avatar
wrap a piece of tape around each hose and a piece around the vacuum port or whatever it came from.
mark the Hose (A) and mark where ever it came from (A)
that's how i did it.
i also bagged all of my bolts. and Labeled them.
always tape all of your plugs too..the same way.
Old Jul 21, 2010 | 06:13 PM
dirtysteve's Avatar
Another good Idea is lots of pictures. At every stage of tear down. Also try to get pics from different angles. I am in the middle of the same project. I hope I labeled everything adequately.
Old Jul 21, 2010 | 06:48 PM
jskijoe's Avatar
+1 on the pictures. I must have snapped a thousand pics doing my 3.4 swap and it helped a lot. It's also faster than tagging things too but not when you're putting it back together.
Old Jul 21, 2010 | 09:50 PM
4runnerJ's Avatar
thanks. I ended up marking them with tape and took a few pictures along the way.
Old Jul 22, 2010 | 06:01 AM
mfwimg82's Avatar
pictures pictures pictures every angle healps
Old Jul 22, 2010 | 08:02 PM
4runnerJ's Avatar
ok, I have another question, Is it possible to remove the engine without removing the transmission?
Old Jul 22, 2010 | 09:26 PM
scope103's Avatar
Photos and tags are excellent ideas, but each has its own drawback. I suggest you do a third as well: draw pictures. Figure out where each line goes, and then draw a simple stick picture showing where to put it back. You'll need to draw several angles, but this isn't the Mona Lisa. You just need to capture the "spots" with a lot of connections, and identify each one. For fasteners, you might want to measure the length of the fastener and write that down (you don't need to record the diameter; the wrong diameter won't fit!)
Tags have an annoying tendency to pull off at the worst time. Photographs require a certain amount of luck; you have to have gotten the right angle, and you have to be able to see the line you're trying to re-connect. So my suggestion is to do all three: tags, photos, and a few drawings.
I always use Yogurt containers to hold fasteners. They have a top, you can write on them with a Sharpie, and getting the containers helps build strong bones.
Old Jul 23, 2010 | 02:31 AM
mfwimg82's Avatar
I like the drawing idea I am still not sure about 3 lines on my 3.0
Old Jul 23, 2010 | 11:00 PM
4runnerJ's Avatar
ya the drawing is a good idea. I marked stuff off with tape and was wondering how well that would hold up or if it would fall off.
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
