3.0 Piston- Ever seen this?
Old Oct 13, 2009 | 10:03 PM
vital22re's Avatar
totally a bro
it may be cheaper to 3.4 swap.... a remanufactured 3.0 will run about 2g depend on the shop. i got my 3.4 swap done for 2100... good luck on whatever you choose to do..
Old Oct 13, 2009 | 10:07 PM
9o7yota's Avatar
Originally Posted by iamsuperbleeder
there should be a test you have to pass before buying certain tools like ring compressors, lol
lmfao.
Dude.. AHHHH this picture makes me feel great... this guy must have smoked some INTENSE pot to make that mistake... doesnt mean he made others..but its more of a chance hahaha... oh man..that is so funny.... dude.. if ur pullin it, droppin the pan... ur heads are already off... change ur rings, rebore if u can....or if u cant cuz of money like me u will be fine.. but its not worth puttin it back in after its out and naked like that to not redo ur rings... make sure ur timing is good too...
Old Oct 14, 2009 | 04:40 AM
VToyota's Avatar
Thanks for all the advice guys- Since this was supposed to be a cheap project I'm going to stick with this engine. I'll pull it and go through the whole thing. I bought the 4Runner knowing the engine needed work but it spent it's life in VA so there's no rust on the body/ frame at all! Would be worth sticking a JDM engine in if needed. Is the 3.4 a direct drop in or do other componenets need to be swapped as well?
Old Oct 14, 2009 | 07:28 AM
JonnyBoy's Avatar
The computer needs to be from the 3.4, and it's best to use the 3.4 clutch with the 3.0 throwout bearing...some wiring...but the blocks are the same, so 3.0 motor mounts will work and it bolts up to the tranny. If you're curious for more info, check out www.yotatech.com/f160.
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
