3.0 idle problems
Old Dec 14, 2006 | 10:16 AM
94toyxcab's Avatar
3.0 idle problems
94 x-cab 3.0 v6. I'm having trouble figuring this one out? When I start the truck and let it get to operating temp. it will idle at 700-800 rpm's. Then after driving when I stop at a light or stop sign it will sometimes idle at like 2000rpm's and not drop unless I shut the engine of and restart. Any suggestions?
Old Dec 14, 2006 | 10:50 AM
da_bigg_wigg's Avatar
Try spiking the gas pedal. You may have a sticky throttle cable. I know mine does the same sometimes if I'm cruising down the highway for an extended period of time. I'll push in the clutch and the tach will read way above idle if I come to a stop.
Old Dec 14, 2006 | 02:29 PM
4runnermax's Avatar
I had a similar prob, Had some goo on the throttle cable, cleaned it off and she's fine...
Also check for vacume leaks...(The computer should be able to compinsate for most of this kind of prob, but somtimes not)
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Jnkml
Jul 6, 2015 01:20 PM
