3.0 gets hot uphill only
Old Aug 29, 2013 | 06:57 PM
  #41
ThatGuy1295's Avatar
"Inu" that is the most ridiculous thing ive ever seen.
Ill typically store my antique vases in the washing machine on spin cycle for safe keeping.
And if all else fails on the trial ill use my macbook pro as a high lift jack base to prevent sinking in the mud. And if I see that 2 vehicles are about to collide ill typically throw myself between them to cushion the hit. And last but not least ill typically stick the most fragile item on the vehicle in the most "likely" place for it to get damaged.
Ps thats nothing to brag about
Old Aug 29, 2013 | 07:13 PM
  #42
Kiroshu's Avatar
Higher RPM "overheating" normally indicates a coolant "flow" problem.
Old Aug 30, 2013 | 01:36 PM
  #43
RSR's Avatar
RSR
Originally Posted by Punchy
RSR, post #11
Ridewrapper, Thankyou for reposting it again.
As for the the size of a trans cooler, Unless you live in the extreme cold climate location going oversize only helps, Its cost and fit that make the restriction.
Old Aug 30, 2013 | 02:40 PM
  #44
Inu's Avatar
Inu
It was a temp fix thats worked. Im going to either make a 3/16 plate full skid and efan or move it to the back next season. Spotters hated the first mount. Just giving options for the guy.
Old Sep 1, 2013 | 02:53 PM
  #45
RSR's Avatar
RSR
Btw -- noticed recently that proper auto tranny operating temps are in the maintenance section of the manual (had looked previously in the A/T section and only found the 158*F lock up solenoid disengagement temp mentioned):
Check that the fluid level is in the ”HOT” range at the normal operating temperature (70 – 80*C or 158–176*F) and add as necessary.
http://personal.utulsa.edu/~nathan-b...nce/2maint.pdf
Again, this suggests value in a minimum temperature range. Still torn about running a thermal bypass valve: http://www.ebay.com/itm/TRANSMISSION...-/321082407626
the1998sr5
15
Jul 14, 2020 08:35 PM
crammit442
7
Nov 29, 2017 12:30 PM
129Creepin
Aug 5, 2015 10:12 PM
mtc1105
Aug 4, 2015 08:06 PM
the1998sr5
Jul 16, 2015 06:20 AM
