3.0 ecm 89pick-up/93 fsm
Old Feb 16, 2008 | 03:30 PM
  #101
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
Originally Posted by jbyrdman
Well got it all changed, set timing took it for a spin.....wow!!!! It runs great, but I guess it should all said and done I replace/repaired
1. Spark Plugs (NGK Platinums)
2. Spark Plug Wire set (Beldin Cables)
3. Distributor Assembly, Rotor and Cap
4. Coil
5. EFI Main Relay
6. Battery Terminals and new 8 gauge Negative ground to frame (needed to do that for a while, hopefully will get rid of engine noise on the cb)
7. Timing Belt
8. Idler bearing
9. Tensioner
Grand total of about 600 dollars. I want to thank you guys for all the help and most importanly the encouragement, this would have cost me alot more than it did, plus I wouldn't have the satisfaction....Thank You all very much. Man how cheesey
Now I can continue to address issues that were there before and got put to the back because of the timing belt. I'll search and/or start a new thread if need be, but since I got your ears.........
1. Fuel Injector Leaking (hopefully just an Oring)
2. Pitman Arm (?bushing kit?)
3. Whistling sound from front left tire
4. Thermostat (test to see if good? temp gauge never changes)
5. Fuel Filter
6. Front end rebuild (where can i buy a kit? new pulleys etc...)
7. rear end sag
Ok I'm done, I could keep going, but this is a long post already...Once again, Pete, Thook, TNRabbit, can't thank you guys enough, hopefully I can help someone else out now and give back to the yotatech community, I'm now a believer!! WOOOHOOOO DRIVING THE YOTA AGAIN! I'M OUT!
You are the Man.Yotatech is a great site. Thanks for giving it a shot. thook and tnrabbit are like my big brothers. I knew they could get you going in the right direction. Congrats
pete
Old Feb 16, 2008 | 06:29 PM
  #102
thook's Avatar
4. Coil
5. EFI Main Relay
7. Timing Belt
8. Idler bearing
9. Tensioner
5. Fuel Filter
7. rear end sag
Oh what a feeling!, eh? (Now, that's cheesy!.... )
Well, it's up to Pete, I think...it's his thread...to continue on here. But, for the reference of the members and new ones to come, you might start a new thread. Break it down individually to address each issue or just lump it all into one with whatever title you want. You'll probably get more input that way, too.
Congratulations on a job well done. The satisfaction is what I like about it, too. Good excuse to break out a good cigar!
Old Feb 16, 2008 | 06:30 PM
  #103
thook's Avatar
pete
And hey! We didn't blow up his truck, either! Ha!
Old Feb 16, 2008 | 06:57 PM
  #104
pete f's Avatar
When I doubt call in the Calvary!!!I hear the bugle now.Dah Dah
jb451
7
Oct 7, 2022 06:58 AM
JHalcyonM
Sep 14, 2015 01:10 AM
Gone Fission
Sep 4, 2015 12:18 PM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
pplusent
Sep 2, 2015 11:56 PM
