2nd gen pickup rear window removal
Old Jul 20, 2008 | 01:20 PM
Swansen's Avatar
Just wondering if anyone has ever done it??? it looks like it just pops out, but with my luck, i'd get to taking it out, and i'd miss something and then it would just explode...
Old Jul 20, 2008 | 03:02 PM
Robert m's Avatar
its really easy. just have a buddy there to help catch it.
http://personal.utulsa.edu/~nathan-b.../6backwind.pdf
just use a wide flat head screwdriver to pry the bottom corner of the weather stripping out when someone is pushing on it.
Old Jul 20, 2008 | 03:11 PM
idanity's Avatar
easier in the warm weather too...
i heard of fishing line helping, but i would want gloves too.
it should just pop out (make sure you use big surface tensions and not a pointed force)
Old Jul 20, 2008 | 04:06 PM
Cyberman's Avatar
Even easier if you have one with sliding glass. I've done it, and it's best to start on a corner, and work your way across, then up (or down).
Old Jul 20, 2008 | 04:33 PM
HAVOC's Avatar
I just pulled mine (sliding rear glass) yesterday. I took a razor blade and cut the bottom of the weatherstrip (inside the truck), gave the window a little push from inside, then it pulled out easily.
This method only works if you wont be reusing the weatherstrip.
Old Jul 21, 2008 | 09:21 AM
Swansen's Avatar
awesome, thanks for the info, looks like my next project.
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
