2nd gen 4runner gearing question.
Hey guys, I snagged a rear end from a 2nd gen 4runner before it got crushed at the junkyard. Now please, if someone could organize this in my brain. It was a V6 Auto, which i thought would be 4.88. Then I brought it home and saw it was pink which would imply 4.10, correct? I counted the teeth which were 41, which would also imply 4.10. I thought that the 4 Cyl Auto came with 4.30's and the V6 Auto came with 4.88's. Or was it purey based on tire size package from factory? Or, did I make all of this up?
If you know your gears are stock, check your axle code. Otherwise count teeth like wabbit said or count driveline rotations if you don't want to open it up.
http://home.4x4wire.com/erik/diffs/#ratios
http://www.brian894x4.com/Gearratiosanddiffs.html
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
