2500 rpm at 55 mph?
2500 rpm at 55 mph?
I'm a little new to toyota, just got my first pickup on the road. The truck is 1993, 22re, 5 speed, 4x4. At 55 miles an hour the engine is turning 2500 rpm. I was just wondering if this was normal.
Alright, thanks for the input. I might hook up the GPS and see what it says speed-wise. My mom followed me home and said she was doing 60 and I was walking away from her. My speed stayed between 55 and 60
Well that's a little different. That will only tell you the accuracy of your speedometer gear. I'm assuming your truck uses a mechanical speedo gear and not electric. It goes on the base of the input shaft and is splined to tell you the speed for stock tires. I have about a size or two above stock and my speedo is still close to accurate, but they're all a little off. Your moms car isn't perfect either. It's just really really close. What size are your tires anyway?
You'll need to check your door for the "A/TM" code (Axle/transmission).
Translate the Axle code, via info here
Then goto one of the gear calculator web pages, like this one, and input all the info.
With my transmission and gear ratio and your tires I'd be reving 1860 @ 55 in 5th. Or a little over 70mph at just under 2500rpm.
Definately check your speedo vs the gps, speeding with an inaccurate gauge just gets you two tickets instead of one
1uzRunner
63
Nov 10, 2018 03:58 PM
anniesball
10
Sep 15, 2015 05:41 PM
zz_denis
Sep 6, 2015 03:43 PM
