22rte master cylinder help
Old May 26, 2012 | 03:38 PM
17toyotaman's Avatar
So the master cylinder in my 87 toyota 4x4 turbo truck went out. Calling around to the auto parts stores in the area, no one has one or thinks they can get one, I'm wondering maybe if I bend the break line that goes on the front part of the cylinder, I might be able to use a regular 22re master cylinder? Anyone know if there are anything that could hinder me from doing this? Maybe a V-6 master cylinder will work? Any advice would be helpful, it went out just about as I was going to try and sell it to fund my 1980 project
Thanks for reading
Old May 26, 2012 | 03:52 PM
conquistador's Avatar
I recently upgraded to a 1" bore master from a 2nd gen v6 4runner or 3rd gen hilux. Only modification is bending the front brake line to get it to connect to the side rather than the top. I really like the stiffer pedal compared to the old one. I ordered mine from Marlin Crawler $89.
Old May 27, 2012 | 08:33 PM
spideynut's Avatar
Im sure its a V6 version. Did you see if they carried those in stock. Bet it mounts right up. Brad
Old May 27, 2012 | 11:56 PM
wyoming9's Avatar
Wink
if you are able to make your own lines just about any that bolt up should be able to work.
The only real difference I can see is where the ports are.
My one Turbo truck had the Master cylinder upgraded or changed but I have no idea where it came from.
My one has a heatshield one does not
4.34runner88
Feb 7, 2016 02:24 AM
Hugh_Mann
Sep 16, 2015 03:59 AM
old87yota
Sep 9, 2015 12:39 PM
Squigglez
Sep 4, 2015 07:33 AM
