22re wont start AGAIN
Old Apr 24, 2010 | 03:29 PM
  #41
vital22re's Avatar
totally a bro
so with the fuel pump running...
have some one check for spark while you're cranking it.
Assuming you still have spark and fuel pump is going and it has gas...
then the injectors arent' firing. ecu controls injectors.
you stated you have a code for no sta signal, that signal comes to the ecu from breaks off to the cold start injector/cs injector time switch, then goes up the cor relay and keeps going to the starter relay and finaly ends that the ignition switch.
you have not answered my question on what you ment by not starting. Does the starter engage and turn the motor over? or is there just clicking?
Old Apr 24, 2010 | 03:45 PM
  #42
Blue_petersen77's Avatar
oh, and it couldn't hurt to check all your fuses either
  #43
KcYotaChick21's Avatar
The starter engages and the motor turns over like it wants to start but it doesnt.
Old Apr 24, 2010 | 03:46 PM
  #44
and already checked all fuses and replaced a few relays
Old Apr 24, 2010 | 03:52 PM
  #45
vital22re's Avatar
totally a bro
try starting it using the clutch cancel switch
Old Apr 24, 2010 | 03:58 PM
  #46
vital22re's Avatar
totally a bro
try finding a fsm for the ecu for your truck. It'll help with tracing where the STA signal wire would be running.
  #47
I just tore apart the wiring harness stuff for my o2 sensor and there are major fried wires... Im going to go ahead and try to rplace them and see if it makes a differnce... SOrry guys i checked all the wiring but I just remembered I didnt tear the whole line up to see if under the plasic there was anything...
Old Apr 24, 2010 | 04:06 PM
  #48
vital22re's Avatar
totally a bro
solder and heatshrink.. dont use butt connectors.
Old Apr 24, 2010 | 05:31 PM
  #49
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I agree with V all the way, for the o2.....solder and heatshrink all the way.
Old Apr 24, 2010 | 05:35 PM
  #50
vital22re's Avatar
totally a bro
also.. the signal wire for the o2 sensor is sheilded on the main harness side of the plug. By sheilded i mean this is an insolated wire in the center and around that is a metal wire wrap and then its insolated again. Make sure the shielding wire does not touch the signal wire. The shielded wire is grounded at the ecu.
Old Apr 24, 2010 | 05:40 PM
  #51
You're welcome
Old Apr 24, 2010 | 05:59 PM
  #52
It didnt change anything... But Ill work on it more 2marro.. Im frustrated and stuff right now..
Old Apr 24, 2010 | 06:26 PM
  #53
then time to stop for the night. You'll have a better outlook 2mrro......
Old Apr 24, 2010 | 11:09 PM
  #54
Yeah lets hope so... Im going to start looking at the ignition switch and wiring again sense the codes read there was something wrong with it. Ill go through all of it and try it out.. We will see... Im not sure really what to look for or check because its a new switch I may put the old one in and see if it trys to start better maybe the switch i got was messed up
Old Apr 25, 2010 | 04:05 PM
  #55
It has very weak spark...
Old Apr 26, 2010 | 06:13 PM
  #56
Weak spark........coil and/or igniter. How goes the wire splicing?
Old Apr 26, 2010 | 06:17 PM
  #57
Fixed all the wires that were screwed up.. HATE THAT STUFF... && I did a new coil.. Is there any way to check the ignitor???
  #58
Also my dad has given up and wants me to take it to a shop...
Old Apr 26, 2010 | 06:57 PM
  #59
Hmmmmm, not sure, but I'll look in my FSM......
Old Apr 26, 2010 | 07:14 PM
  #60
I really don't see a procedure for testing the ignitor itself The FSM just shows and explains how to test the coil, dizzy cap, and spark plug wires. Have you tested the sprk plug wires, themselves? Changed them recently?
