22RE valve cover removal is a Pain!
Old Mar 18, 2010 | 10:12 AM
pruney81's Avatar
Here's a few pics of the chips on the head and one pic of where it appears to be seeping through. I don't know if it was leaking this bad before or not, it might well have been. The rest of the cover is sealed up pretty good, I'm thinking about just putting some black RTV on the outside where it's leaking and see how that holds up.
The chips are small but they are the only shiny sections where the head meets the cover.
Attached Thumbnails 22RE valve cover removal is a Pain!-sdc10044.jpg   22RE valve cover removal is a Pain!-sdc10047.jpg   22RE valve cover removal is a Pain!-sdc10046.jpg
Old Mar 18, 2010 | 10:28 AM
92 TOY's Avatar
like I said, i took a plastic spackle knife and drove it in under the cover in the area of the passenger's side front by the hoist hook thingy to break the seal.2 knifes rammed in there and you could probably wedge a good size straight edge screwdriver in between them. I wouldn't pry against the head anymore though...it's only aluminum. doubt you did any hard there though.
Old Mar 18, 2010 | 10:38 AM
pruney81's Avatar
I'm definitely not going to pry anymore. I'm going to try to get it done tomorrow I guess with the help a pretty savvy friend. I bought some black RTV, if I don't change the half moons should I dab some of that on them?
Old Mar 18, 2010 | 10:39 AM
92 TOY's Avatar
sounds like a plan
Old Mar 18, 2010 | 10:40 AM
  #25
pruney81's Avatar
nice, thanks 92, it's finally warming up here in Mass, I'm excited to see your truck up and running again.
Old Mar 18, 2010 | 10:47 AM
  #26
highonpottery's Avatar
sounds like you just need to use your man hands, lol. i'd go out and get yourself a rubber mallet. give it a good whack and it should unseat. a rubber mallet is a good thing to have around anyways.
Old Mar 18, 2010 | 11:58 AM
  #27
92 TOY's Avatar
It's not up and running, but I am at working on it again. thanks all the same.
Old Mar 18, 2010 | 01:25 PM
  #28
pruney81's Avatar
it will be soon on account of the good weather was my point.
Old Mar 18, 2010 | 01:39 PM
  #29
92 TOY's Avatar
gotcha.............
Old Mar 18, 2010 | 02:35 PM
  #30
1stgen4gunner's Avatar
Are you kidding?!?!?!
GET A SLEDGE HAMMER AND SMASH THAT F*&%ER OFF!!!!
Just kidding (never smash Aluminium with hammers), did you try prying it with a screw driver while your friend hits it with the mallet?
Old Mar 18, 2010 | 02:38 PM
  #31
pruney81's Avatar
we didn't take the grommets out the other day so I think that was the problem, Tomorrow I'm going to try hitting it with a rubber mallet after I get the grommets out and I picked up a couple of razor blades too. I won't be doing any more prying.
Old Mar 18, 2010 | 03:49 PM
  #32
Matt16's Avatar
Or, use a blow torch to soften up those grommets- they're the only thing holding it in place.
Old Mar 18, 2010 | 04:04 PM
  #33
pruney81's Avatar
Yeah, I know I don't know why I didn't remember that the other day. That's a major fail on my part. It'll be fixed tomorrow for sure. I bet when I get those grommets out and give it a little tap with a rubber mallet it'll pop right off.
Old Mar 18, 2010 | 04:16 PM
  #34
rusche's Avatar
Take a big flathead screwdriver and tap it inbetween the valve cover and the head with a small hammer. I've never had any trouble.
Old Mar 19, 2010 | 03:36 PM
  #35
pruney81's Avatar
Got the new gasket on today and sealed up nice with some black RTV. Also, my timing chain guides are intact and everything looks nice and clean under there. I'm pumped. This truck was definitely taken care of. Now, all I have to do is bleed my brakes tomorrow and then drive to California next month. I think it will make it.
The valve cover came off no problem after I unscrewed the grommets.
Old Mar 19, 2010 | 04:04 PM
  #36
Jay351's Avatar
Those stupid grommets are stronger then you think
Old Mar 19, 2010 | 04:15 PM
  #37
pruney81's Avatar
Well, it looks like the stock ones actually thread on there, as opposed to the Fel-Pro ones I bought which just slide right on. Unless, they aren't supposed to be threaded and they just fused to the bolts over time?
Old Mar 19, 2010 | 08:11 PM
  #38
hodgepodge79's Avatar
bingo.
Old Mar 20, 2010 | 01:44 AM
  #39
Western Canuk's Avatar
You set the valves while you were in there right?
Just a side note about your drive. Last year a friend of mine drove his '95 4runner (22re) from Calgary to San Francisco on a blown clutch and still 6 months later. He says as long as he doesn't rev it in 4th it's all good.
Toyota's always get you where you going.
Old Mar 20, 2010 | 08:04 AM
  #40
Bridger5228's Avatar
I love how there's a 2 page thread on valve cover removal that DOESN'T get moved to "Newbie Tech.", but all my threads do......Wow....
